What will a TH350 Handle? Many Th350 Quetions, Shift kits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2005, 04:20 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I have a stock Th350 from 1975 with about 100000 on it, what kinda power will this handle? Will rebuilding it increase strenght? Do shift kits do anyhting to make it handle more power? Trans cooler? What parts should I install for it to handle more power? Sprag?? Clutches? seals? plates? What shift kits do u guys prefer? whats been your experiences with em? How do manual valve body ones work?...coudnt i use my currnet valve body and treat it like a manual couse cant u just shift into low1 then low2 then shift into drive and itll go into 3rd?? Is their kits to convert my valve body to a manual/automatic one to get the best of both worlds.? Thanks
Old 12-18-2005, 06:39 PM
BOBCRMAN@aol.com's Avatar
Answers= 1. 250, maybe.
2. yes, if built with performance parts
3. yes
4. recommended
5. High performance clutches, steels. sprags, shift kit.
6. yes, high perf roller clutch
7. yes, red line, or various other hi-perf.
8. yes, many different brands
9. Kolene or similar
10. Trans-go
11. excellent. Great customer service. Reliable and time tested.
12. Modify the shifting points and valving so trans can be held in any gear at any time.
13. if you want to drive that way.
14. See 12
Old 12-18-2005, 09:46 PM
Warrant's Avatar
250!?! thats all! wow i would have thought more. Well, if i rebuild with the high perfomence part mentioned, sprag and all that, What could it handle? what if it wasnt built with new stronger sprag? Thanks
raising th350 shift points Jmark Transmission - Rearend 4 07-27-2005 11:08 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
TH350 WOT shifting eball Transmission - Rearend 1 09-05-2003 10:09 PM
late 2-3 shift in th350 with transpak joeyg329 Transmission - Rearend 2 07-19-2003 03:32 PM
TH350 will not shift at WOT quadman_20 Transmission - Rearend 5 04-14-2003 11:20 PM
