What would be the best Cam for a 474 street engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-27-2010, 10:11 PM
I have a pontiac 455 bore out to 4.211 the cam I would like to use is a 51-433-9 comp cam 236intake 242Exhaust. Will this Cam be a good street cam?
Old 09-27-2010, 10:39 PM
ericnova72's Avatar
More for Less Racer
You might send a pm to WDCreech, he is probably the most Pontiac performance oriented guy on this board. He can tell you who to talk to as far as Pontiac specialists go.
My thought is that cam is too small, but you didn't give car weight, rear gear ratio, rpm range you are looking for, converter stall, max rpm redline, cylinder head used, stock or aftermarket connecting rods, or exactly how streetable you need it to be. Just a street cruiser, or some strip time also?? Do you tend to be a racy type, or not??
Old 09-27-2010, 10:54 PM
techinspector1's Avatar
Wiki Edits: 326
Agree that WD Creech would be the man to talk to, but
Yeah, I would run it on the street.....
HYDRAULIC ROLLER − Rough idle,
needs 2800+ stall, lower gears and
9.5:1-11.0:1 static compression ratio.
If I were going to use it, I would want a good set of aluminum heads, high-rise dual-plane intake manifold, 850 carb, large-diameter equal-length headers and 10.00:1-10.25:1 SCR, minimum 3.73:1 rear axle ratio, preferably 3.90-4.10. I'd also want to set it up with a tight squish. Here's some verbage from Edelbrock that may help....
http://www.edelbrock.com/automotive_...6000/60579.pdf
Old 09-27-2010, 11:25 PM
The car is a 1968 400 Firebird 3200-3500 lbs. I don't know what the rear gear ratio is, it is still stock. The heads that I'm using are Pontiac 6X-4 Heads ported, EAGLE or SCAT H-Beam 6.800" Rods. The rpm range I would like is from 1800-6000. This is the first time rebuilding an engine so....I'm trying to get all the help I can so I do it right.
The list of parts from Butler performance is
467-474 cu in balanced assembly
comp cam 51-433-9
Hydraulic lifters & roller rockers
springs for the pontiac 6X-4 heads
Ferrea 2.11 intake
Ferrea 1.77 exhaust
The intake and carb I don't know yet
Old 09-28-2010, 01:10 AM
ericnova72's Avatar
More for Less Racer
If Butler Perfrmance pointed you in the direction of that cam, I would go with it, they know their stuff. Glad to see you got a better rod in it.
Old 09-28-2010, 01:34 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I don't think I could add anything to that, except that if you are going to use a turbohydramatic transmission, you could probably gat away with using rear gears in the 3.50 or deeper range, but you will need a converter with at least the 2800 stall that techinspector suggested.
Bill
Old 09-28-2010, 01:49 PM
Is a 2800 stall too high for driving on the street with a turbohydromatic transmission? would I be driving in first all the time to keep the rpms up, I read someplace that a high stall like 2800 is hard on the engine & transmission as it wouldn't reach 2800 rpms very often. The application would be street and the odd time at the strip and the car would be driven maybe 6-12 times a month.
Old 09-28-2010, 04:16 PM
WDCreech's Avatar
A 2800 stall converter is not too high for street use! I had a 5500 stall in my '63 LeMans and as long as I didn't stand on it, it worked fine for around town. The rpm would climb a bit when I started up a grade.
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 08:35 PM
Buick 430 Engine 70LEBUICK Engine 5 02-24-2010 10:57 PM
1985 C-6 truck tranny, no engine braking effect fast68 Transmission - Rearend 40 02-04-2008 06:55 PM
SBC cam for the street, hydrulic or soild lift tiresmoke55 Engine 19 09-01-2006 11:22 PM
engine eats cam lobes 1969chevytruck Engine 13 10-08-2005 11:57 PM
