Assuming stock bottom end, you may be as low as 8:1 comp right now....with 76cc heads. Small Carb, no comp, bigish cam, all of this spells dissapointment. If your leaving the bottom end as is, then get heads with a 58cc chamber, run a 0.015 head gasket, get yourself a 750 Carb, and watch as all of it comes together and makes far more power then you currently have. Call this guy. Speier Racing Heads and tell him what you have, and want to accomplish. His prices are excellent, he is available all hours of the day...and will tailor the heads to your combo.....ie: 58 CC chambers for 10:1 compression.
And there you are. |
| The Following User Says Thank You to bygddy For This Useful Post: | ||
73nova350 (01-28-2013) | ||
Check out a site called ASA Performance in Columbus Ga ,also listed as ,abad71camaro.same buisness he has aluminum sbc heads 64cc 200 or 220 runners Complete and assembled For Under $800 with free shipping.lots of locals run these ,I donot mine is a Big block with custom aluminum heads ,Good luck
Lots of good suggestions here, but at the end of the day research is your friend. The dart SHP'S seem to be somewhat dissapointing, the brodix IK's have a great rep for the most part, the kmj is procomp stuff, not saying its good or bad....just saying do you research. I went with the Pro-Filers because they are price wise comparable or cheaper then the brodix or dart, yet being compared with, and some claim better then a much higher priced AFR eliminater head. And there was enough info out there to make a somewhat educated desicion. And when I E-mail a company at 10pm at night hoping to hear back the next day, and get a response 10min later. (Speier Racing Heads) I'm happily surprised. Unfortunately he was out of stock at the time, but still answered my questions, and still reccomended the pro-filers.
Some food for thought...some inane arguments, but when its a fight over which is better, the pro-filer or the afr, you know your in good company either way. How to choose the correct cyl head - Page 2 - Chevelle Tech Profilers 195 vs. Afr 195 - Page 2 - Team Camaro Tech Air Wolf 220 Results - Chevelle Tech |
thanks for all the info guys, any idea on the power gain i would get out of this?
what would be the best heads
I wouldn't think there is anyone that can tell you what size combustion chamber to purchase without knowing the piston brand or the volume of the piston. (Flattop-5cc dished-18cc). While the heads are off measure the distance from the top of the block to the top of the piston. Write it down and keep it handy because you will need it to figure your quench, head chamber volume, and compression ratio.
find a set of vortec heads they are the best cast iron heads gm has with a valve job and port work and bowls blended these heads are pretty impressive
So, again, here's the way to say it..... L31 Vortec heads are the best flowing SBC PRODUCTION cast iron heads that GM ever produced. Hang in there, it gets easier...... |
i have a edelbrock 600 carb with vac secondaries and i also have a holly 650 double pumper with mechanically secondaries, which one would be better with this setup
If you want a better flowing GEN 1 head, you have to go to the aftermarket. Lift limitations are fixed by springs/retainers. They do require a dedicated intake. If you want to take a production head, slap it on a shortblock with the goal of making the most power/torque, the head that will do the job is the Vortec L31head. Not only are they great heads, GM never installed a better GEN 1 head on any vehicle they ever made, car or truck. peace Hog. |
| 305 heads or 350 heads on sbc 355 | ryan v | Engine | 7 | 09-20-2012 10:21 AM |
| swapping 351W heads for 302 heads | babell7738 | Engine | 10 | 01-21-2012 10:16 AM |
| 462624 SBC heads vs Patriot heads?? | v8hed | Engine | 2 | 05-27-2008 09:25 PM |
| SBC cylinder head bolts .. cast iron heads Vs Alum. heads | terror385 | Engine | 3 | 08-04-2006 08:34 PM |
| Vortec heads or 1971 487x LT1 heads? | speedfrk3 | Engine | 2 | 10-07-2002 04:12 PM |
