Thomsons Water seal works Great if you put water on the bare metal first then put the sealer on after that water !!!!!!!!!!
I cant do that to you but i felt i need to make a smart *** paint sugestion that this forum is use to seeing !!! not shur what a aero panel is im sorry there a few to use not shur on application and situation your talking about a picture of panel helps but lets say it was a bare metal door skin no ecoat if inside your door you wanted it painted and buffed then go that route if you just didnt want it bare after you could use a direct to metal primer with a roller that wont go bad on you and leave it like that if its hidden and roll the panel edge flange over onto door frame ! dtm primer is great for that ! there is also a wax that is sprayed in there on some applications such as wheel wells and frame rails that is from 3m . but you should use a metal etching coating ! metal prep is just a etch cleaner in some cases not a coating !! if i knew more about your project i can give you MY choice of product ! |
I am not sure what exactly you are doing either, but I was taught on bare metal to metal condition it, with either metal prep or self etching primer and then epoxy prime. At least thats what I car procedures were. I sometimes skip the metal prep myself if the metal is clean and I am going to be sanding it. When we got new panels in at shops that I worked, they usually came with some black primer on them, I don't think its ecoat. We always just shot undercoating on the inside of the panel and sanded the outside and put a few coats of good urethane 2k primer on the outside of them. Not sure if anything would be better to use inside them besides undercoating, but if it is truely bare steel, you are probably going to want to at least epoxy prime all the bare metal. Epoxy primer seals from water more then a urethane primer does.
Sorry Fellas
I should have been more clear. The new panels I bought, are for a Aerostar Van. I have used things like Prep coat, but I cannot find it any more. The panels are unpainted body panels, Cross Canada here does not sell prepped panels anymore. I was thinking of POR15, but I cannot even find that ether. I have restored a 2 Mustangs complete and a few other cars. My father and Father in law used old 50s stuff (Prep coat) years ago. But have I have been out of it for a few years. So I'm not new at this. I am just trying to find new stuff to use before I weld them on. As I said they are bare metal, and would like to at least do the damn rockers. The paint shop has their own brand of prep but at 60$ a gal. The old stuff I used was 10$ in Ontario, Canada. And it worked great, but out here in Newbrunwick, their 10yrs backwards. If anyone has any ideas. Thanks |
sand with 80 grit then prime with epoxy, remove the epoxy from the weld areas and apply a weld through primer there, after they are installed spray down the inside of the panel with 3M's Rustfighter cavity wax.
| secrets of surface rust removal revealed | Randy Ferguson | Body - Exterior | 178 | 09-24-2011 09:36 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| Rust damage repair | oils65mustang | Body - Exterior | 1 | 04-14-2004 09:52 AM |
| Phosphoric Acid + Prevention of flash/surface rust | unstable | Body - Exterior | 3 | 07-21-2003 07:36 PM |
| How desirable are 1950 Fords?? Good deal? | '54-Hunter | Hotrodders' Lounge | 7 | 02-08-2003 07:51 AM |
