What would be a good set of heads to use with a crane energizer cam
Im building a motor for my brother and on a little budget I have a crane energizer cam with a 454 lift and the heads are a mis match what would be a good head to use with this without going to vortec
Loosen up there Danny and give us some numbers. Cam number, head casting number, what pistons and piston deck height, what intake manifold, what carb, what trans, what rear end and what rear end ratio, what tire?
The motor/converter/trans/diff must all work together as one unit to make the power where you want it to be and be reliable. |
Sorry im building a sbc 350 bored .40 over 4 bolt main I have the whole motor but was told the 624 heads are a mismatch for that cam he has a truck but needs a motor and like usual wants alot done for cheap im not looking to make a monster it is a mexico made crate motor I believe the target buster 10066036 casting the cam has a closed 105 lbs and a open 265 272 duration min rpm is 2000 max is 5000 and lift is 454. I can have the heads worked by my buddy but was wondering what heads I can use without going vortec and spending alot I do have access to a salvage yard due to the fact I work for a company who has one my main question would be is what heads would match this cam I am using flat head pistons
Shop around for a set of casting number 882 or 441 heads. These could also crack, so you will want to make a deal with the guy you get them from, that he will take them back and refund your money if you produce a magnaflux certificate that shows them cracked. Tell him he can stamp the heads anywhere on a non-machined surface that he wants to, so he can later identify the heads as the ones he sold you. That way, if they're valid when you bolt 'em on, they're probably gonna be alright because you, as a hot rodder and appreciator of all things that turn money into noise, will be diligent about maintenance on your short. "short" is a name for a car that was used when I was a teenager. The guys were looking for a shorter name for "car", so they settled on "short". Kinda funny if you see it from my perspective. I'll get further into this motor if you want to. Last edited by techinspector1; 01-15-2012 at 04:57 PM. |
I know vortec are the way to go I just built a 355 with vortec heads around 400 hp for myself im not wanting to go super perfomance just got the cam lifters and a double roller timing for almost nothing brand new the cam that was in it had a flat so im doing this I have a set of 882 s I was going to use but thought I would double check cuz I have gotten very good info off here before
I didn't see this lad's immediate need as being performance. More of a "lick and a promise" kind of build for his brother. Last edited by techinspector1; 01-15-2012 at 05:28 PM. |
Thanks for your help I appreciate it he is putting it in a 86 silverado that someone had a 307 in the motor was junk but the way I see it cheap or not there is still a way of doing it right I would have liked to go vortec on it but there is alot to change to do so
I ran a big roller cam in my stock shortblock 350 LT1 engine. With the 62cc heads my static compression was 9.2-1 . The cam was 242/248 @.050" with .584/.579" lift on a 114. More compression would have been nice but it pulled very hard at the track. I don't lose sleep when the compression numbers don't exactly work out. He's going to spend $300 or more getting a set of 882's cleaned up, with a valve job and new guides put in. I would just yank a set of Vortecs off of a pickup truck in the junkyard. Pull some valve covers and find the set with no sludge. There's your heads. |
If I just yank a set of vortecs then I have to yank a new mani new brackets spend more on plugs tall valve covers and all ill just get a set of 882s have my buddy that owes me a favor do a head job on them and spend nothing
Sounds to me like you already had your mind made up? Why make the post? |
| Crane 290 H Any Good ? | adantessr | Engine | 40 | 11-10-2011 10:30 PM |
| Good old Pop, the 1919 version of the Energizer Bunny | deckofficer | Hotrodders' Lounge | 7 | 09-27-2011 08:31 AM |
| stock 350, 50 chevy truck, crane energizer 274 | vintagecar | Engine | 2 | 11-17-2010 01:25 PM |
| Engine Crane Vs Alum Heads | BUCKOLA | General Rodding Tech | 4 | 05-19-2010 01:44 PM |
| Crane Energizer Cam question | stfinney | Engine | 5 | 11-13-2002 05:57 AM |
