Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What would have to be changed to use Buick tranny in Suburban
Old 09-11-2012, 12:15 PM
HRCessna HRCessna is offline
The bell housings are the same, as far as I can tell. On some swap guides I have noticed the trucks will fit the cars, so that means the bell housing will fit. The wiring inside is one of those things I'll need to check, but I'll be taking the pan off both anyway, so that won't be a problem. Thanks for the heads up on that. I'm not sure the solenoids are the same, or the wiring plug, or the cooler line hookups...but I think all that can be swapped. I'm assuming the torque converters will be a bit different, and so not sure if I should use the one from the sub or the one on the Buick.
