What would be required to change a 400 SBC to serpentine belt setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2003, 07:23 PM
banned
Post What would be required to change a 400 SBC to serpentine belt setup
Just curious about building the engine to have a serpentine belt setup since there are tons of cars out there now with the serpentine belt (caprices with 305 tpi especially)... would all this require some extra acessory holes for the tightening mechanism?
Old 02-09-2003, 08:56 PM
BigBlockBabe's Avatar
Missing You
Post
I'm sure it can work the same way as Fords (cause Chevies are cheap and easy. :p )
All I've gotta do to go to a serpentine setup on my 429 is find a late model setup and get all the pullies and brackets.
Or if you've got the coin, March Performance makes some niiiiiiiiice billet serpentine setups, but they are spendy.
Old 02-09-2003, 10:51 PM
banned
Post
well my thought was to pull the whole setup off of a tbi caprice
Old 02-10-2003, 01:16 AM
E.T. divided by $ spent= Speed
Post
Depends on what ya mean by serpentine set up.I have a serpentin belt(flat wide)on my 78 montecarlo.It came off my 85monte.All that mine is,is it runs the same as a V belt(around crank,waterpump and alt using alt to adjust tension)except its a flat belt.All I did was change the crank pully,waterpump pully and altenater pully.The PS is still run by a small V belt.Was the only matching pullys I had,also had a new belt,so ya can't beat logic.
If ya mean the setup with the tensioners and idlers and all that,can't help ya.
[ February 10, 2003: Message edited by: 78 monte ]</p>
Old 02-10-2003, 03:31 AM
aka Duke of URL
Smile
Old 02-10-2003, 05:18 AM
jalopy45's Avatar
Cool
Take the caprice setup including the water pump, I believe they have reverse rotation, if they do, you could have cooling problems.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
Old 02-10-2003, 05:24 AM
xtreme off-road's Avatar
Post
[quote]Originally posted by jalopy45:
<strong>Take the caprice setup including the water pump, I believe they have reverse rotation, if they do, you could have cooling problems. </strong><hr></blockquote>
This is true. If you use a v-belt pump, the impeller will unscrew from the shaft.
<img src="graemlins/drunk.gif" border="0" alt="[drunk]" />
Old 02-10-2003, 06:02 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
GM has them for after market, depends on the accessories. Approx. price is $285. on up.
www.spoperformanceparts.com/
Luv the smell of NITRO in the morning.
