Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What would it take...
Old 06-21-2004, 03:52 PM
Ghetto Jet's Avatar
Ghetto Jet Ghetto Jet is offline
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
You're right, this is a car you are going to drive every day there isn't much you should remove or replace to lighten it. Tearing out most of the interior, a/c, heater, inner fenders, stereo, speakers, ect. Would only take off about 200 pounds, .2 of your et. Not the right route to take IMO.
The Performer is isn't much better that an stock 4 barrel intake, the Performer RPM is designed for performance and will give you more all around power. http://www.73-87.com/chp/dyno3.htm look at test 2 and 3, the difference between the test are they went from a Performer to a Performer RPM and switched to a Holley(which probably only added a few horse power, the majority of the increase is because of the intake.
