What would you build for my project? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 08:24 PM
Well folks, friday night i was driving the truck down the ring road, decided to open her up a bit and before i know it the engine decided it didnt want the #7 rod in the block any more. Some parts are good, (cam, heads, intake, ect.)
With only 3-4 weeks until cruse season, i am missing an engine.
So if you were in my situation, what would you build for your truck?
BTW, the truck is a 62 gmc. TH 400 with a 12 bolt in the back. 3.90 gears. I use it mostly for crusing and driving around but i like the wow factor of the crackle coming from the headers and a lope.
Any ideas would definatly help on what to build next.
Old 04-01-2012, 10:23 PM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
A 383, 10:1 compression, 230-236 @ .050 hydraulic roller cam, a set of 200cc heads with some mild cleaning up, dual plane intake, 750 vac sec carb, simple HEI ignition... Recipe for a nice 430hp/460tq (easily), pump gas, your gears are good, and a 3000-3200 stall. Would cruise well and "haul the mail"
Old 04-01-2012, 11:48 PM
327NUT's Avatar
I would be very careful and build something that didn't throw a rod.
A long-distance build project dharder Introduce Yourself 2 09-20-2011 01:20 PM
Engine Build Project gebudjr Engine 3 03-11-2011 04:45 PM
New scratch build project going on texas97z Hotrodding Basics 2 11-10-2009 08:04 AM
buddy build up project! 72fordlb Engine 12 04-29-2009 08:57 AM
project 496 build best47 Engine 1 04-05-2008 06:36 PM
