What would you choose? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2005, 09:19 PM
I have a one 383 with 400 crank and rods it has about 50 000kms on it but looking at the short block it looks like it even has less
I also have a 355 it has 3000kms on it someone nicked the crank while putting in arp rod bolts so I got the rods re sized the crank turned and all the arp bolts put it basicly a new motor
I have a set of 041X heads ported with new guides and unleaded seats
I have a Performer Rpm manifold and a Perfomer Rpm Air gap manifold
I have a Carter 635 Comp carb and a Holley 750 Dp
I have new Comp 981-16 valve springs a Isky 280 mega cam and a Comp Xe274
I have a built th400 with a 2500rpm stall
sanderson 1 3/4 primary 3 inch collector shortys
what ever combo I use will be going into a 86 S10 blazer with 3:42 gear (untill the stock rear blows)
what would you put together and why?
Old 04-20-2005, 10:35 PM
Was also looking at getting a better set of heads like Dart Pro 1's or The new Gm high performance vortecs
and a new cam
How do I choose the right size jets? mde Engine 2 11-25-2004 10:01 PM
Help me choose a good name for my small workshop. Francis General Rodding Tech 8 07-24-2004 01:31 PM
Do we have to choose? muscarmad Hotrodders' Lounge 7 07-15-2004 03:17 PM
How to choose rims??? arborlis Suspension - Brakes - Steering 1 03-16-2003 08:50 PM
idle to 5500 or 1500-6500? help me choose! 7fastelc0 Engine 3 11-13-2002 07:07 PM
