what would you recommend to improve my engines performance
hello everyone i have a 87 iroc and i would like to improve my engine its stock im not to good with engines so what would you recommend(street legal)it has a 350 engine with a 350 manual transmission
It will be a TPI motor. There are a few free mods you can do to free up some power. TB bypass-your car has hot coolant flowing into the throttle body and out the other side. This design was put into place to keep the throttle blades from freezing up in sub 32 degree weather. Simply unhook both ends from your throttle body and then use a small piece of tubing with some hose clamps to connect them together. Try to find a flared piece. MAF sensor--take it off of your car and remove the screens on either end. This will improve the airflow into the engine. Make sure you run your car with an air filter at all times. Catalytic converter--unhook it from the exhaust and hammer out all of the pieces inside. Make sure it is legal to do so where your state laws apply. Some states require strict vehicle emmision testing others do not. |
This can be done with Engine, VIN, or casting numbers and observation as to whether it has a carb or injection. Bogie |
The group over at THIRDGEN.ORG are the kings of this stuff it seems. Some of the following is TPI specific, most works for any V8 engine in these cars from the factory.
I would get an aftermarket free flowing cat converter (or 2 if your car requires them). A better quality Y pipe and midpipe, along with a nice single muffler 'cat back'. Believe it or not, the factory air intake on the TPI's are very good, just use a quality air filter. The throttle body bypass (TB BYPASS) is good too, and removing the screens from the MAF is okay, but theres some conjecture that it can cause problems, so I never did it to mine. You could get a set of aluminum heads off of a similar year corvette, but you'll probably want to grab the intake as well because the EGR is set up differently on vettes. The A.I.R pump doesnt take much at all on these cars to spin. So as long as it spins freely by hand; you should leave it and the AIR tubes that go to the exhaust manifolds in tact. If you want headers, forget longtubes and forget a true dual setup....its really really not worth the hassle. If you still want headers, contact Dyno Don on ThirdGen; he makes some amazing stainless ones. You'll also want a small laptop and some serious time on the TGO (thirdgen.org) PROM tuning boards. Good Luck |
Blue bottles work wet . My neighboor has a 100hp wet shot on his Civic EX 1.6L 5 spd . Really charges forward like you would not expect. Probably puts 200 hp to the wheels.
87 iroc
thanks for your help im looking to get the most horsepower out of it so i would appreciate if you keep giving me ideas (my engine has a carburator) i will definitely check out thirdgen.org
| I have a modified 4.9L TBI Eldorado and want to improve performance. Please help! | EldoDave | Engine | 23 | 08-19-2011 12:21 PM |
| Float level, how does it improve performance? | spinn | Engine | 14 | 09-20-2010 07:20 AM |
| Recommend a book for a performance rebuild of an Gen 2 LT1? | McDeuce | Engine | 1 | 11-11-2008 02:24 PM |
| What can I do To Improve Performance? | Silentlion_69 | Engine | 6 | 10-08-2004 05:22 PM |
| performance engines | badknuckles | Engine | 7 | 12-27-2003 09:01 AM |
