Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what year is this chevy 350?
Old 03-07-2012, 06:06 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
The sending unit should be easy. Simply find a junk car that had a SBC in it, if the sending unit is ran off 1 wire as mine was then just simply cut yours off and splice in the replacement. Difference in the 72 and 80 engines? The casting numbers on the heads will be different unless someone has swapped them at some point. Since your engine has some age on it that's quite possible. The 72 engine had a drivers side oil dipstick. The 80 engine had a passengers side dipstick.
