What year clear - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 06-29-2013, 02:47 PM
Trucknut's Avatar
What year clear
Does anyone remember what year car companies switched from single stage to base/clear? I'm really interested in when GM/Chevy started using bc/cc.
Thanks
Old 06-29-2013, 11:42 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Pretty sure that GM started using BC/CC in 1985 or 86. not sure if all cars got the BC/CC but almost positive the camaro's of 86 used it.
Kelly
Old 07-01-2013, 08:54 AM
Trucknut's Avatar
Thanks, Carolinacustoms. Ironically, it's a 1982 Camaro that I'm wondering about. Appreciate your help.
Old 07-02-2013, 07:55 AM
82 seems a little bit early to be BC/CC if it has the original paint, But keep in mind that the factories are notorious for secretly trying things without telling the public until they see how it works, so it is possible. To find out if it is a single stage or BC/CC just sand a spot with 320 until your see color (of course this is if you are doing a repair). It will be easy to tell if it is clear coated or not. If a red car sands with white dust, then red dust it is clear coat.If the dust is the paint color immediately then it is a single stage (or the clear has came off). When you sand through to the metal, there will be three different layers on a BC/CC or two layers on a single stage (laquer, enamel, urethane) there will be bare metal, primer(factory is usually gray), then color, then clear (if it has clear). Any particular reason for wanting to know?
Kelly
The Following User Says Thank You to carolinacustoms For This Useful Post:
Trucknut (07-02-2013)
Old 07-02-2013, 11:34 AM
Trucknut's Avatar
Yes, there is a reason. This car has only 11,000 miles on it, with the original paint. The car is like new and perfectly straight. The fellow that owns it wants numerous chips repaired and color blended. I think it's better to paint the whole car. He's bringing it to me today and I'm trying to figure out the best way to get the best results. I don't think I can give it the look it deserves by spot painting it. Any thoughts would be appreciated.
Thanks for asking and any possible answers you have.
Chris
Old 07-02-2013, 01:35 PM
the year before is started peeling off
Old 07-03-2013, 04:44 PM
Well even though it only has 11,000 miles, it still has 30 year old paint, which may or may not be in good condition depending on how much sun, weather, moisture etc it has been exposed to. I would probably try to talk him into an all over unless you only have a small place or two to fix. Blending or matching would likely be a pain with the paint that old. Good luck with it.
Kelly
Old 07-03-2013, 08:44 PM
Trucknut's Avatar
That's my take, also. I talked to him today and I'm painting the whole car. BC/CC. Thanks for your input. I'll try to take and post pictures tomorrow.
Old 07-03-2013, 09:26 PM
You certainly welcome sir. Hopefully it was of some help.
Kelly
Sanding orange peelin clear before final clear coats 67Elcamino Body - Exterior 4 05-25-2012 01:47 PM
Quadrajet float level: Carb year or CAR year? itstorque Engine 12 11-02-2010 09:17 PM
sanding clear then repaint with base clear agian questions tiptopss Body - Exterior 8 04-20-2010 08:09 AM
Can I respray clear on top of clear that has dried if I sand it.. makaveli200369 Body - Exterior 5 07-02-2006 09:12 AM
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 08:55 AM
