What Year is of my ford 302 motor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2010, 11:50 AM
Hi: I have a 1923 t bucket with a ford 302 in it. My question is how can i tell what year this motor was built and where will i look on block to get that information.
Thanks!
Chuck Bell
Old 09-21-2010, 12:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From HERE:
"The quickest path to block identification is the casting number and date code found above the starter on the right-hand side of the block on 221/260/289/302, Boss 302 and 351W/351C engines."
Old 09-21-2010, 12:38 PM
Wiki Edits: 31
Yep.. casting number has the date as a letter and a number
C= 1960's
D= 1970's
E= 1980's
F=1990's
number is the actual year... so if you had an E7 casting, then you would have a 1987 engine.. or D8 would be 1978, and so on
Ford 302 marine motor timing setting. digithead1 Engine 0 05-26-2009 11:53 AM
FORD 302 vice FORD 302 Hipo Kauai Hawaii Engine 6 11-09-2008 01:27 AM
Ford Motor Company backs down -- forum will publish calendars Jon Hotrodders' Lounge 17 02-14-2008 05:10 AM
help with seeing wut size "FE" ford motor i have rebelcowboy50 Engine 1 12-01-2005 09:00 PM
Ford 302 into a 1940 Ford questions. cyberbear Engine 2 07-20-2004 08:29 PM
