what year is my motor?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2010, 06:48 PM
the numbers arent on it but it does have the two piece seal for the crank and a three bolt starter?? taking over a project and it didnt come with the starter or flywheel and i cant find a starter to match the big flywheel.
Old 07-13-2010, 07:06 PM
lol ford, chevy, AMC??? BB, SB?
Old 07-13-2010, 07:26 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Waiting,
Cole
Old 07-13-2010, 07:53 PM
350,maybe....
lol,350,no idea what year but i was just told there are more numbers behind the dis,hopefully i can find out..ha
Old 07-13-2010, 07:56 PM
eloc431962's Avatar
Wiki Edits: 37
We know it's before 1986 because that's when chevy went to a one piece RMS. And if you have the 168 tooth flywheel you will need the staggered pattern for your starter, And if it's the 153 tooth you will need the straight across pattern. And they have a starter that will work for either pattern also maybe a little pricey though.
Cole
Old 07-13-2010, 08:00 PM
eloc431962's Avatar
Wiki Edits: 37
Oh, and with the three bolt holes try going with the outer bolt hole and it should line up. JMO
Cole
AR RACING 383 Motor 64Duece Engine 27 05-20-2013 01:02 PM
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Fired new motor big problems. ForceFed86 Engine 2 06-14-2010 08:27 PM
1968-1969 olds 455 engine is this good and how can i id 1968olds455HO Engine 5 09-02-2009 11:53 AM
wiper motor won't run cboy Electrical 14 05-03-2006 09:44 AM
