what years are compatible - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2004, 06:22 PM
stoney 81ta's Avatar
what years are compatible with a 81 ta i have a chance to get a 78 0r 76 z28 with good body and front end parts will they work on a 81 ta
Old 06-07-2004, 12:48 AM
There may be some differences in the outer wheel bearings, and also in the brake caliper hardware, but otherwise they should be the same.
Old 06-07-2004, 05:52 AM
tks jim so the sway bar tie rods and control arms and front fenders should work
Old 06-09-2004, 12:46 PM
I don't know about fenders. Some of the TA's did have a much thicker front sway bar that required larger frame brackets than most F-bodies came with.
Old 06-09-2004, 04:55 PM
bullheimer's Avatar
NEVER use credit cards!
fenders go around the outsides of the lights at least. i dont see anything fitting except door and some suspension stuff as they have different grills/lights si'?
Old 06-09-2004, 10:21 PM
so more less im out of luck for the fenders but i could use some of the front end parts
