What Yoke? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 08:17 PM
What Yoke?
I am picking up a Mopar 360 w/trans (early 70's) has about 60,000miles on it and it came out of a motor home! My question is what trans is in there and what yoke should I order? Thanks, Dana
Old 02-21-2009, 10:13 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the transmittin would be a 727 trans...
Old 02-21-2009, 11:27 AM
You are 100% correct, just found out yesterday, thanks again, Dana
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 12:38 PM
TH400 Can I replace a fixed yoke with a slip Yoke? Double_v23 Transmission - Rearend 4 08-07-2008 07:31 AM
slip yoke doesn't (slip) on... markzepp820 Transmission - Rearend 14 04-29-2008 02:29 AM
Ford 9 Inch pinion yoke length?? baddbob Transmission - Rearend 15 05-31-2007 12:40 PM
th400 yoke question L78Chevelle Transmission - Rearend 2 06-06-2004 08:56 PM
