What you guys think about this - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 04:38 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Found this listing on craigslist. Please comment accordingly
http://littlerock.craigslist.org/pts/2800708400.html
Old 01-26-2012, 11:34 AM
TroyBoy's Avatar
Psychomotors
What are your plans for the stuff if you buy it? 305, 350 etc? It would be a real nice package for a 305. I probably would pass on it just because I won't use someone elses used cam. But thats not too bad for the heads and other stuff. Depends on what you are needing and what you want to do with it.
Old 01-26-2012, 12:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I agree, the cam and heads pass, the rest is OK. Will he break the 'set'?
Old 01-26-2012, 01:18 PM
1971BB427's Avatar
I wouldn't ever put a used cam and lifters into my engine. No way to discern which lifter went on which lobe, and once it's broken in they will have matching wear patterns. Mixing them uo will cause more wear on startup. Cam/lifters are so reasonable these days, it's not worth using used.
The heads are OK, and the intake carb is too, but I'd offer less and get your own cam kit.
Old 01-28-2012, 03:45 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
guess a lot of the replys, didn't read the ad.
" Lifters numbered to hole they where removed from."
.. I'd still ask less..
Old 01-28-2012, 03:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I wouldn't trust someone else to be as careful as you have to be to get the lifters "numbered" to the hole they came from. If the numbers are 1-16, what is hole #1 and what is hole #9, if they are "Left 1-8 and Right 1-8", is that looking at the front of the engine or from the driver seat? And even if they are "Driver side 1-8, Pass. side 1-8, or the exact way they are numbered is understood, were there any lifters that somehow got out of order?
Then there's a question of manufacturing tolerances and core shift that effects the exact placement of the lifter bores to the camshaft. ANY of these can frag a cam and that will be the most expensive "cheap" cam you ever bought.
Old 01-28-2012, 03:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by cobalt327
I wouldn't trust someone else to be as careful as you have to be to get the lifters "numbered" to the hole they came from. If the numbers are 1-16, what is hole #1 and what is hole #9, if they are "Left 1-8 and Right 1-8", is that looking at the front of the engine or from the driver seat? And even if they are "Driver side 1-8, Pass. side 1-8, were there any that somehow got out of order?
X2 i have to agree with cobalt here i would not chance it.IMHO
Cole
Old 01-28-2012, 04:33 PM
stich626's Avatar
gearheadslife
with todays oil I'd not run a flat tappet. new if I can help it..
Old 01-29-2012, 01:51 PM
1971BB427's Avatar
I wouldn't run with todays junk oil either, but there are oils still available to use with flat tappet cams that work great. Just not found at most run of the mill parts stores.
I'm running flat tappets in all 3 of my hotrods and no problems.
Old 01-29-2012, 01:59 PM
stich626's Avatar
gearheadslife
ya, but the oil or additive isn't cheap..lol
I have a 355with comp 292 that I built in 92 thats never run.. that I'm at odds with.. do I change the cam or not..
hey guys bopedersen Introduce Yourself 4 02-23-2008 05:46 PM
what do u guys think stoney 81ta Engine 7 02-20-2008 04:29 PM
Hi guys bonjourblink182 Introduce Yourself 5 02-16-2008 08:36 AM
Hey Big Guys!! Lloyd1wv Introduce Yourself 5 10-01-2007 07:42 PM
hi guys I need some help 231_Romona Introduce Yourself 3 11-10-2004 06:06 PM
