What are you guys using for a tranny stand? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2009, 08:27 AM
scapegoat's Avatar
Looking into rebuilding my first th350 and was wondering what you guys were using for a tranny stand. I have seen the ones that look like a big C-clamp that looks like it would mount up to an engine stand. I don't know who sells these though.
Old 10-01-2009, 09:32 AM
yes that is the GM tranny fixture it actually mounts to a base that yu bolt to a bench...they are around 170 bucks very good to have if you are planning on doing trannies. I have used old 41te cases or 604 I have also used 5 gallon buckets with a hole bored into the top of it back in my learning days
Old 10-01-2009, 12:16 PM
larrym's Avatar
Don't laugh, I used a workmate table opened it up dropped the tranny in.
The wood top did not damage the case made things easy.
Old 10-01-2009, 12:22 PM
Irelands child's Avatar
If I'm doing my usual Ford C4 - the bell housing is a separate piece - then it's just my phenolic work bench top and a few wood blocks as that is about as light an auto trans ever made. A C6 or TH350/400, then I'll improvise with saw horses and 2x4's. Not the best, but my transmission work ---- seldom, thankfully
Dave W
Irelands child
SSedan64's Avatar
C-Clamp style>> https://www.700r4l60e.com/store/prod...&cat=63&page=1
Rear clutch spring compressor tool>> https://www.700r4l60e.com/store/prod...&cat=63&page=1
Old 10-01-2009, 04:39 PM
Put a big punch in a vise standing up and hang the tranny case on it thru a bellhousing bolt hole
Old 10-01-2009, 05:57 PM
tnsmith10's Avatar
when will it rain???
727 or 904 case turned upside down for a rear wheel drive. for a front wheel drive trans, depending on the builder or shop, either a fixture like mentioned above is used or they drill a hole in the bench and use a nut and bolt on the face of the case (depending on which trans) through 1 of the bellhousing holes and bolt it to the bench.
Old 10-02-2009, 10:34 AM
scapegoat's Avatar
I like the bucket idea. Spending more than $100 on a tool to hold it is not worth the one rebuild I would do.
Old 10-02-2009, 11:19 AM
When I rebuilt the 350 in my truck I used a roll of duct tape (4x4 transmission, the output shaft is real short) when I needed to stand it on end. For dis-assembly and cleaning I "built" a work table using a pair of saw horses, some 3/4" plywood, and a metal drip pan with a hole drilled in a corner for a drain (with a bucket underneath). Worked extremely well for my needs, and the table was even strong enough to handle the cleaning needs of a SBC 350.
Old 10-02-2009, 08:52 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
5 gallon plastic bucket with a flex plate sitting on top of the bucket is something I used for about 2 decades till I actually bought a trans case holding fixture
Old 10-03-2009, 06:49 AM
With all the dealerships going out of business around the country, the availability of normally expensive tools is considerable. I have been able to purchase an engine hoist, hydraulic press, commercial grade parts washer and a Ford style bench fixture that I have used for C4's, T5's and 9 inch carriers. I got everything for $400. Could have had a 4 post lift for $800 but didn't have the room ( down in Louisiana they can't go outdoors).
Old 10-03-2009, 01:17 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I made one out of scrap steel and welded an allthread union (long nut) on the one side and a piece of tubing on the other. The tubing slides into an engine stand and I use a bolt in the threads to clamp in the tranny.
Old 10-06-2009, 08:48 AM
scapegoat's Avatar
Any of you guys have any pictures of your homemade tranny stands?
Old 10-06-2009, 09:16 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
A $2.50 5 gallon bucket from Lowes (bell housing end up, of coarse).
repairing an old engine stand quick50stng Garage - Tools 3 01-26-2007 11:06 PM
Tranny Questions JRS1967 Transmission - Rearend 1 08-24-2003 01:01 AM
4-speed tranny making noise!!? chevyelc81 Transmission - Rearend 6 08-04-2002 08:23 PM
'66 Chrysler 300 Torqueflite 727 tranny removal Bo_Jangles Transmission - Rearend 10 03-05-2002 08:43 AM
70 roadrunner engine and tranny Oddi Engine 1 11-23-2001 01:38 PM
