what are your project vehicles - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-17-2008, 12:13 PM
65 ImpalaSS. Body's mostly straight, interior's there but blue changing it to black. Currently no engine/trans. Working on getting enough money up to do something besides stare at it
  #17 (permalink)
Old 06-17-2008, 12:59 PM
31 five window
Last journal entry: grill and rear end
Chopped top 31 model A 5 window coupe.Homemade frame,350,700R4,9"rear narrowed myself,Flush closing suicide doors and rear 4 link with coil overs.I am also installing a 305/TH350 in a friends 40 Dodge that NEW INTERIORS helped me put a S10 front clip under.
  #18 (permalink)
Old 06-17-2008, 03:53 PM
cboy's Avatar
Last journal entry: Finished
'32 Ford Pickup with 460 and C6 trans. Daily driver during summer season.
'31 Ford Roadster with 351 Ford and C6 trans. Built in this journal
Sedan Delivery Pickup with 302 Ford and 3 speed. Currently under construction in this journal
Always learning...and sharing what I've learned.
  #19 (permalink)
Old 06-17-2008, 04:03 PM
72 grabber 51F-1 65 chevystang
that red truck sure is nice The 460 is just icing on the cake
  #20 (permalink)
Old 06-19-2008, 06:56 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Here's what I'm working on now. A 1967 350 one lung Montgomery Ward.
That's the motor setting in back of the frame. For no bigger than that motor is it's like picking up a large rock. Whew!
ID:	30731   Click image for larger version
  #21 (permalink)
Old 06-19-2008, 07:07 PM
Wiki Edits: 31
That company made a little bit of everything didn't they?
  #22 (permalink)
Old 06-19-2008, 07:20 PM
couple pics of the monster
  #23 (permalink)
Old 06-19-2008, 07:26 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
Originally Posted by Brian_B
I only have one project. The one in my avatar.
It is a 1956 Ford F-100 that is almost all original. 272 Y-block, 3 speed on the column, 3.73 (original) rear end. Original seat (re-covered), original steering column/wheel, drum brakes all the way around, etc.
It does have carpet and a headliner now. I also have power brakes (under the floor) and a set of gauges in it (mounted under the edge of the original dash).
It is not pretty, but it is a blast to drive.
I was not aware we were posting pictures. Since the first post I have added a vacuum resivour (under the cab), a console (sits on the seat), new to me tires, shocks, and mirrors. The new mirrors are not in this pic:
Here they are:
  #24 (permalink)
Old 06-19-2008, 07:32 PM
the 51 F-1
the 72 maverick
http://www.hotrodders.com/gallery/da...2_maverick.jpg
my 69 F-100
  #25 (permalink)
Old 06-19-2008, 10:11 PM
jerw55's Avatar
projects
66 chevyvan panel, 230 six, a cult classic!!
  #26 (permalink)
Old 06-19-2008, 10:14 PM
life is a temporary assignment
A 34 ford 3 window coupe with a LT1 In it,and a home made 27 model t rat rod.
  #27 (permalink)
Old 06-19-2008, 10:25 PM
Brian_B's Avatar
Lost in the 50s!
Originally Posted by jerw55
66 chevyvan panel, 230 six, a cult classic!!.....
I think all those smaller vans from that era are cool.
The econoline and D-100 (?) were similar in a lot of ways.
  #28 (permalink)
Old 06-21-2008, 04:56 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I've got a house addition to finish first, that won't be done until the end of the year. Then I've got some choices: build a boat, or build a car (first! hope to eventually do both).
Boat: probably a Bolger "Sneakeasy" with a few minor mods (http://www.alaska.net/~fritzf/Boats/...Sneakeasy.htm). Considering adapting a small inboard to it. Maybe a 500cc water cooled Honda V-twin bike motor, shaft drive. That would be interesting (it's a light boat, 24' long but only 4' wide... I intend to increase beam to at least 4' 6" though).
Car: Stuck between a lot of work on a 62 Rambler American (61-63 look the same) or less work on a 65 American. Both are two door post sedans. Either will be a roadster, most likely powered by a Ford 2.3L turbo engine with T-5 I've got from a Merkur XR4ti, will use the IRS also. Lately, however, I've been considering selling the Merkur engine and turboing the old Rambler flat-head six... Not as much power, but would be real big on "cool factor", and quite economical. The 196 flat-head was rated at 90 hp, 7-10psi would increase power to a more respectable 135-150, which is probably the limit, but it would have LOTS of low speed torque!!
For the 62 I've always wanted to section about 3" out of it all the way around to lower the beltline, remove the roof leaving the windshield frame and vent windows, and weld the doors shut, filling the seams and leaving the roll-up windows in the doors only. Roll bar will be rectangular tubing or a twin tube bar, welded into the chassis to make up for lack of roof. No opening doors, so no worries about a front brace bar blocking them!
I've had the 62 for a while, but recently got a 65. The 65 wheelbase is within about 1/2" of the Merkur. For that one I'd take the roof off and build the roll cage, but might leave the doors opening. In the latest "Rod and Custom" there's a drawing of a Falcon with the T-bird hard tonneau cover. Thinking that would be the way to go with the newer 65. Could weld the doors shut and move the cowl back a few inches, and even section it a couple inches, but if I'm doing all that may as well do the 62. I think the older styling would look cooler with the l;owered beltline and welded doors. If I do the 65 it will be because less work is involved, except for the tonneau cover.
  #29 (permalink)
Old 06-21-2008, 06:19 PM
Old Gold's Avatar
52 Packard 200 Deluxe
  #30 (permalink)
Old 06-22-2008, 06:27 AM
38 special's Avatar
Be the MIRACLE!
Cool trucks/van guys.
Sounds like great boat project Farna, keep us posted. I added on to my house last 2 yrs ago and the inside still insn't finished. Nice chevy65/66 Impala?
New Member 1st Project 86 Cutlass 86cutty Introduce Yourself 4 03-27-2008 04:00 PM
Project motivation americanLT1 Hotrodders' Lounge 24 05-23-2007 02:11 PM
Displaced Arizona rodder signing in, project pics inside!! TheVis Introduce Yourself 3 01-21-2007 04:15 PM
Project planning 580Z Hotrodding Basics 5 04-27-2005 03:20 PM
