What is your ride? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-29-2005, 01:16 PM
firestone's Avatar
http://teamrfc.gospelcom.net
1969 firebird
358 ci 14.7:1 compression
LAE 3.295 stroke billet crank
GRP billet aluminum rods
brodix 11-x heads ported by HVH
~270@.050 solid roller cam
glide with 5000 stall and brake
dana 60 rear with 488 gears
3200 lb with driver
7.15 1/8th on motor
6.29 1/8th on a 100 shot
Motor was reciently taken apart, getting a set of Comp AFR 227 heads, steel rods, and a nitrous cam, along with a turbo 400 and 4.56 gears so in can be run in the 1/4.
1989 firebird
383 10.5:1 compression
steel 3.75 crank
pink rods
AFR 210cc street heads
236 242 @.050 .520 .540 lift hyd roller cam
Victor JR intake
turbo 400 with 4000 stall (too much stall, I know)
ford 9 inch with 3.89 gears
3600 lb with driver
7.85 1/8th
Motor reciently lost a lifter and was torn down. Short block is being replaced with a 420 stroker. Cam is being replaced with a 248 254 @.050 .582 .585 lift solid roller.
1969 camaro
327 ci 11.5:1 compression
forged rotating assembly
dart 200cc iron eagles fully ported
cam mid 250's @ .050 solid roller
turbo 350 tranny with 4500 stall
12 bolt with 5.13 gears
not sure of weight
7.4 1/8th
Motor was sold and car is being built for the pump gas drags/drag week with an N/A 10.5:1 598, AFR 357 heads. Hoping for solid 9.xx on motor in the 1/4.
These cars are actually my dads, but my brother and I race/work on them.
Adam
  #17 (permalink)
Old 11-29-2005, 03:01 PM
bigbadbowtie's Avatar
Bottle Fed
Daily driver
1986 Chevy C10
bone stock 170000 mile 305
Wifes is a 2005 Toyoter Camry
Weekend car. 500 to 1000 miles a summer and countless p*****/bottles of go gas.
1978 z28 Camaro.
355 chevy
Gm crank,rods,KB pistons.
TFS heads
Lunati solid roller 630/630/ 254/266 on a 106
crane/comp/PSI valve train
Vic Jr intake
Chuck Nuytten 850
TNW nitrous plate
Th350 manual valve with a PTC 9" 4000 stall
4.56 gear with spool,clip eliminators
8 point cage.
car weighs 3450 without me.
It runs 11.8x's@115 N/A
Its been 10.76 at 127 qtr with a 1.56 60. Since I moved I only run 1/8 but its been quick enough there to run in the 10.6x range with a 152 60ft.Thats foot braked on 125 shot of nitrous.
  #18 (permalink)
Old 11-29-2005, 04:54 PM
Siggy_Freud's Avatar
Firestone do you build anything small lol?
Nothing with a stall under 4000 . . . go big or go home your motto?
Bringing history and technology together.
  #19 (permalink)
Old 11-29-2005, 05:02 PM
Wiki Edits: 31
1951 Chevy Fleetline Deluxe 4dr
Rare Powerglide W/ 235 I6
62,300 original miles
keeping it stock drive line but custom ( deep grape purple paint, purple and white vinyl interior )
Runs and drives but still being restored ( Body on )
1967 Ford Falcon Futura 4dr
200I6/ cruisomatic
104,000 miles
will be daily driver
  #20 (permalink)
Old 11-29-2005, 05:46 PM
firestone's Avatar
I guess so, but ironically, my favorite street car was my 1972 Ventura with a 10:1 vortec headed 355 with the XE268H cam and a stock stall. It was really snappy, not the fastest of the cars, if fact probably the slowest, but it was a blast stoplight to stoplight it also had a 700R4 and a 3.90 gear with a posi so that helped the quickness. Unfortunately, I pulled out in front of a car going 60 and totaled it; my fault. By the way, have you had your truck to the track?
Adam
  #21 (permalink)
Old 11-29-2005, 05:55 PM
71 vw super beatle
8 point cage, full 2x3 tube frame
mustang II front suspension, rack and pinion
narrowed ford 9"
283, 60 over with 305 heads mild summit cam
tpi intake, MSII computer
turbo 350 trans
no leg room
  #22 (permalink)
Old 11-29-2005, 07:42 PM
WV hillbilly
Last journal entry: PTL 220CC
Well, a 74 nova and a small journal 327...
wanna Race?
2wld4u
  #23 (permalink)
Old 11-29-2005, 08:35 PM
Parisienne66's Avatar
(Daily)
1998 Jeep TJ SE, Bonestock.
Fun driver/project
1966 Pontiac Parisienne 2dr coupe
283ci, Power Pack heads
4bbl Q-jet
RV cam
1 5/8 Headers
Dual 2 1/4 Exhaust
Powerglide 1.82
90% restored, still need bits of chrome redone, some problems fixed, etc...
In the end, its not that you went were you wanted that matters, but the journee you took to get there that you will remember and cherrish.
Based on Homer's Philosophical writings.
  #24 (permalink)
Old 11-29-2005, 08:39 PM
1973 firebird
runs low 10's on pump 94,and low 9's on 250 shot and race gas.Entire car cost $18,000 to build.check it out a
thttp://www.homestead.com/schmidtracing/TheBirdPage.html
My other car is an almost stock 89 GTA 5.7L black on black.It is mildly tweaked and runs low 14's as a daily driver.
And I drag all my stuff around with a 2003 chevy HD 2500 short cab/longbed 2WD with 6.0,and a 22 foot 2005 Patriot enclosed trailer.
Here are 2 pics of my hotrods,lets see if they come up.
  #25 (permalink)
Old 11-29-2005, 08:41 PM
Oh,and the blue bird is being repainted.Here is the most recent pic I have of it.One 1/4 needed to be redone do I cropped it out of the pic.The color is 1970 camaro citrus green.
  #26 (permalink)
Old 11-30-2005, 06:35 AM
engineczar's Avatar
Going to move this thread to the lounge
  #27 (permalink)
Old 11-30-2005, 07:23 AM
Bottle Fed
NICE ride super streeter. My next engine will be a BBC. Im gonna run my little engine that could one more year and then its going in my truck(if its still in one piece). 468 or 496....somthing bigger than I have.
  #28 (permalink)
Old 11-30-2005, 03:54 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
38 DeSoto, humpback with split rear window and suicide doors.
1981 Kawasaki 1,000 LTD
1967 Montgomery Wards one lung 350cc Riverside.
46 Chevyfleetline, the answer to your question is use a carpet/utility knife and cut out the oil spot then cover with a throw rug. She'll never see it.
  #29 (permalink)
Old 11-30-2005, 04:27 PM
46chevyfleetline's Avatar
Last journal entry: A few more
Hey 38 thanks for the info but it's too late. Dingle berries are now hanging from the christmas tree. ho ho ho (3 octives higher) Cheers!!!!
  #30 (permalink)
Old 11-30-2005, 05:56 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
67 Nova 2 dr hard top
388 4 bolt main. decked
eagle rods & crank balanced
Performer Rpm heads
Performer Rpm Int.
Herbert solid roller 240 250 dur@.050 .502 lift + comp 1.6 rockers
Comp lifters
Comp Chain
10.5 to 1 compr.
Edel 750 carb
Msd 6a
Mallory super coil
2800 stall
th350
3.55 gear
Increasing Ride Height Slightly - what are my options? hduff Suspension - Brakes - Steering 8 10-19-2004 08:44 PM
WWWOOOHHOOO Air ride baby! flamedfordbronco Hotrodders' Lounge 8 03-11-2004 06:43 PM
Hydraulics vs. air ride flamedfordbronco Suspension - Brakes - Steering 16 01-24-2004 09:46 PM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 08:39 PM
Intel Ride Kit Dutchman Suspension - Brakes - Steering 4 07-16-2003 12:10 PM
