what's a 560 lift? and 390 posi gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2006, 07:48 AM
yea.. i"m border line mentally challanged when it come to this stuff. My car has got this and I have trying to figure everything on it. I check hotrodders dictionary before I ask any of these questions. It just mentioned car lifts.
Old 09-01-2006, 08:24 AM
look,i don't know much but 560 lift is in regards to the camshaft. the bigger the lift the more the valves open. 3.90 is the rear end gear and posi is posi-traction which makes both tires spin. hope that helps. what kind of car??
Old 09-01-2006, 08:25 AM
.560 lift ... is the amount of lift on your camshaft ... ( or the amount the valve in your cylinder heads lifts off the valve seat to allow fuel in/out )
3.90 Posi ... the gear ratio in your rear end ... and it is a Posi-traction
Deuce ...
Old 09-01-2006, 08:34 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
"560 Lift": Probably refers to camshaft specifications. It would actually be '.560"' (0.560 inches) and the other releveant specification would be duration. Camshaft mfr's design many camshafts with differing specs to cover a specific engines operating range requirements.
"Lift" is the distance, in inches, that the valve comes off it's seat.
"Duration" (expressed in degrees of rotation ... eg 224) is the length of time that the valve remains open.
"390 posi"
This refers to the ratio and type of the rear differential.
"390"
is actually 3.90:1. This means that the driveshaft turns 3.9 times to every 1 turn of the wheel. This is a fairly low (high numerically) gearing ... better suited to the street or drag strip than the highway.
"Posi"
is short for "posi-traction". Otherwise known as a "limited slip" or "locking" differential. Most posi's have clutches inside the differential case that engage when one wheel starts turning faster than the other (spinning). When the clutches engage, the power (torque) is divided between the two wheels, and better traction results.
Not all diffs are "posi's". They have no clutches, or other means of "locking", and are referred to as "open" differentials.
HTH,
Don
Old 09-01-2006, 10:54 AM
thanks for your help!
yea, not really for the street.. but fun, I'm making a scrapbook with all this and past information from you guys so thanks!~
to Martell06.. 74 gto ....pictures and info in my photo album
Old 09-01-2006, 11:52 AM
cabowabo's Avatar
big Q
560 lift 390 posi
what does this means
it means get ready to fill the tank up at very gas station
Old 09-01-2006, 12:03 PM
lol... how about no gas station!! needs 110 octane minimum @ $6 a gallon at 8 miles a gallon. (and that's if I don't pound it)
fod 390 and valve lift? joie383 Engine 8 01-14-2006 02:00 PM
