What's 9" differential swap meet value? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2013, 06:57 AM
Irelands child's Avatar
I've about lost touch with the used market and am kind of curious as to the value of a used Ford 9" differential. I'm doing some swap meet crawls over the next month or two and am going to be looking for a complete 3.50 - 3.70 and maybe as high numerically as 3.89 plus open, 28 spline. I wont need a locker or 'N' case either as my car isn't raced nor very high horsepower. I can regear my current case and may, but want to look at the alternatives.
As always, thanks for any inputs
Irelands child
Old 05-16-2013, 08:33 AM
Banned
I'll bet I can get a whole truck 9" for a 100.00
I know where one is at..
I'm in mass .. don't know if thats to far of a drive.. if not.
I can go see what the whole works is.. most times 75-100 if I pull it..
and pulling a truck 9" is 4 bolts, a sawsall to u bolts and e brake cables/brake lines and out..
cake
Old 05-16-2013, 09:24 AM
big gear head's Avatar
High Performance Rear Ends
About $50 for a rebuildable core.
Old 05-16-2013, 09:48 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Dang it, I wished you lived closer (or, vise versa )-I've got a 28 spline, open, 3.50 Gear 9" that I am not going to use-
Good luck, they are out there, I've seen them for well under $250-
Old 05-16-2013, 10:10 AM
Phew!!!. It sounds like they must have gone down in value since my last wanders as I hadn't seen 2.6?/3.0? clunkers a few years ago for less the 3-400 bucks.
As far as that truck rear end - I would bet that's a 31 spline and would need different axle shafts to fit my narrow '57/9 rear end.
If I could find a $50 buck core locally, add a rebuild set of bearings and other parts plus a new set of gears it would end up being a pretty decent choice.
Craig - if you lived closer, we probably would have already made a 'deal' and being the nag that I am, you might even have finished your car
Thanks for the input guys
Irelands child
Old 05-16-2013, 01:51 PM
35WINDOW's Avatar
Gawd, i wish!
Old 05-16-2013, 02:18 PM
What part of 'Upstate' are you? PM me if you like. One of my customers is semi retired and has a lot of cores; he may have just what you need. Im right in Syracuse, a few blocks from the old 'Carousel' Mall
Old 05-16-2013, 02:34 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Just an FYI vans have the 28 spline open rear ends. Try car-part.com to see if a yard has one..
sam
Old 05-16-2013, 04:56 PM
Keep in mind when you ask someone what's it worth... People normally reply with a value much lower than you can actually sell it for. Go on ebay and craigslist too see what their selling for. Chances are a swap meet will be higher.
Swap Meet NoobRodder Hotrodders' Lounge 2 04-03-2013 07:02 AM
Swap meet eloc431962 Hotrodders' Lounge 3 03-07-2010 09:23 PM
The kind of thing you will see at the "Dream Machines" meet in Half Moon Bay. MARTINSR Hotrodders' Lounge 3 03-30-2008 08:19 PM
swap meet? wildtaxi21 Off-Topic 0 06-15-2006 12:21 PM
Meet "Purty GURL" gr8junebugfan Engine 21 09-27-2004 04:31 AM
