whats in the beast ? '90 GMC rally stx - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2008, 07:30 PM
79C10's Avatar
Viva la Migra!!
O.K. , I just picked up a 1990 GMC 3500 rally stx 15 passenger van . It is a one ton model, with a 5.7L TBI motor . The trans is a 3 speed , but the pan is the deepest I've ever seen on a factory vehicle .
What kind of trans came in these beasts ?
How do I decipher the VIN to find out what rear end it came with ?
Thanks -
Mike
Old 02-10-2008, 07:54 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Almost definitely its a TH400 (sometimes called a 3L80) and the rear should be a semi-floating 9.5" 14-bolt.
Find the RPO sticker which might be in the glove box, a door jamb, or behind a removable panel in the back. Rarely its on the inside of the engine housing. Post the list of codes and I can decipher them for you.
L codes are engine
M codes are tranny
G codes are rear axle
90 GMC 350... probably running lean etc etc wickedenvy Engine 8 08-20-2006 06:08 PM
Wiring a GMC Rally Wagon for a stereo? |DyInG_FeTuS| Electrical 2 10-30-2003 09:53 PM
