Whats the best Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2005, 05:06 PM
AMERICAN MUSCLE!!!!!!!!!
Hello, what would be the best gears for a 67 chevy camaro with 327 in it for street. thanks alot Allen
Old 09-10-2005, 05:58 PM
willys36@aol.com's Avatar
Wiki Edits: 21
This topic has been covered in many, many threads in great detail. Consensus is that a ratio in the 3.54 - 3.72 range is just about a perfect marriage of performance/mileage. The exact ratio depends on HP, tire diameter, etc. Any higher and you lose acceleration, any lower and your engine screams and wastes $$ in gas at cruising speed.
smoke's Avatar
Is this a street car? No hiway driving? What size tires do you run? 4 or 5 speed or auto? What rpm range do you run the motor at? This is all to be taken into account.
If you are just racing 1/4 mile what rpm do you want to cross the line at?
2:41 gears in a 81 Firebird 81FIREBIRDESPRIT Transmission - Rearend 8 03-22-2005 07:37 PM
8.5" spider gears onecoomofo Transmission - Rearend 5 06-14-2004 07:41 AM
Exploded spider gears...? (12 bolt GM) Bumpstick Transmission - Rearend 7 10-07-2003 06:00 PM
how to change gears.... jackflash Transmission - Rearend 4 04-10-2003 03:47 PM
SBC Timing Gears MI2600 Engine 1 09-20-2002 08:00 PM
