What's the best Posi for a 1996 Blazer - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2007, 11:08 PM
My wife and I have a 1996 Blazer with an open diff. Looking to put a posi / limited slip / locker in the rear axle. This is a daily driver which sees some off road use when we go to the lake. It could use improved winter traction also
Old 07-06-2007, 07:33 AM
Jmark's Avatar
My son has had excellent results with the LockRight lockers in his '76 crawler. Simple install, works great and only locks when needed.
Mark
Old 07-06-2007, 08:10 AM
RippinRon's Avatar
It could improve winter driving but also put her in the ditch if she isn't used to driving sideways! The rearend will be a 7.5" unless its a zr2 model so any stock posi from a s10, cutlass, monte carlo etc. will work. It depends on how much you want to spend as its just a driver I would get a used stock unit. Posi is limited slip you do not want a locker!
I blew my Auburn posi apart this week end. ElCa/monty Transmission - Rearend 3 07-02-2007 09:08 PM
ahhh what do I do? mixed up beraing cups, budget 8.5" posi install Warrant Transmission - Rearend 7 03-23-2007 08:39 PM
1996 4 door s-10 blazer mural/pattern help ChrisMiddleron Body - Exterior 0 12-14-2003 12:34 AM
1996 Chevy 4x4 s-10 Blazer ChrisMiddleron Body - Exterior 0 10-12-2003 12:03 PM
Pearl 1996 Chevy s-10 blazer ChrisMiddleron Body - Exterior 4 10-06-2003 11:58 PM
