whats the best size pipes for exhaust or does it really matter? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2011, 08:42 AM
i got a 1973 z28 with a 406 sb not sure the cam size, all i know is 520 lift, flat top motor with aluminum heads and 750 dp holley. it runs great but has exhaust leaks everywhere and i dont know too much about exhaust systems. if i went with anything bigger than 2 1/2 pipes out the back would there be a big difference in performance?
Old 05-01-2011, 09:05 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Nope. 2.5 duals sounds right to me for that setup. Any bigger and you might pick up 1-2 hp but it might come at the expense of 5 lb-ft lost in the lower end.
Either way, you won't feel a bit of difference. 3" would sound killer, but it would probably add a ton of interior drone and not really help power.
Old 05-01-2011, 09:11 AM
ok thanks alot. didnt see that this was a repost until after i posted.
Old 05-01-2011, 09:12 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
it does matter alot
whats the car being used for, daily driver?
2.5 dual exhaust sounds about right to me also
if you search there is a ton of info on here about it
x-pipes, h-pipes, where to put and what kind of mufflers, etc.
for daily/weekend driver, i would stick with 2.5" pipe, use an x-pipe and some higher quality mufflers
but i dont know what kind of budget you have
Old 05-01-2011, 09:23 AM
hey matt thanks for the info, my car is a weekend driver and occasionally i will go to the garage and crank her up just to hear her growl but i will look into the x pipe possibility and my budget is only an issue with the wife
Does Size Matter? joeford Engine 9 02-10-2010 07:43 AM
What size exhaust pipes do I need? 71gtx Engine 4 11-14-2006 04:31 AM
Size doesn't matter Madd Syntst Suspension - Brakes - Steering 3 09-22-2003 06:34 AM
Does size matter BIGBLOCKSTANG Suspension - Brakes - Steering 3 03-11-2003 11:27 AM
Size does matter Halloweenking Hotrodders' Lounge 4 05-17-2002 11:57 PM
