Early 60s 327 vette.
Luv the smell of NITRO in the morning. |
I may be wrong but the 4 jet had a smaller base. I am thinking 62 to 64.
Ontario Rodders |
Chevy had early cast Q-Jet, Holley and Carter intakes. I know the Q-Jet and Holley had "R" and "H", respectively, cast on them. I'm not sure about the Carter. These had the oil filter tubes. They're available at swap meets.
Most of the aftermarket intakes were aluminum. |
WHY ?? Are you racing in a class that requires cast iron intake manifolds? THE BEST iron ones are in the GM Performance catalog. They are copies of the famous Z28 aluminum ones but in cast iron. GM made them for the racers... .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
alum. q-jet intake
I have an alum. intake, with GM casted into it. casting # behind the carb 458520. Any body got any I-D what it came out on? Thanks
What's the casting date?
i just found the z/28 manifold copy by GM in the cast version#bow tie 14096011.it is cast and a look a like copy of the z/28 manifold that deuce was talking about.the old cast alum. 65 corvette manifold was the wieand made manifold that is pretty darned good too.i've got a couple of them.
