whats the best tech on rust bubbles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2002, 06:17 PM
Post whats the best tech on rust bubbles?
i know i need to use a wire wheel and get rid all all remaining rust and take off all remaining soft metal.then i would prime and fill with fiberglass bondo then smooth with bondo then sand. whats better and would guarantee no spots after final paint????
Old 11-18-2002, 09:56 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Use Por15 or some other rust converter to be sure all the rust is totally killed B4 bondo and paint.
Old 11-19-2002, 04:02 AM
New Member
Post
I read that rust-killers needs some remaining rust on the metal in order to stop it. Is that a fact?
Pettersen
Old 11-19-2002, 04:50 AM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
The rust converter I have used do need rust to react with. In changes it to a hard primer like coat.
If you have totally removed the rust, and have got the front and back side perfectly clean, I would just glass over it from the back. It will seal it all up. Follow with a good primer and paint or undercoating material.
Chris
Old 11-19-2002, 06:02 AM
Wiki Edits: 21
Post
Turbo is right IF you get the metal PERFECTLY clean. Only additon I would make to his formula is I would paint the bare metal with a ligtht coat of acid etching primer B4 adding the bondo. Primer bonds better to the metal and bondo bonds better to the primer.
Old 11-19-2002, 06:32 AM
TurboS10's Avatar
Wiki Edits: 2
Post
Good point willys. A quick pass with 36 grit will also remedy the bondo adhesion problem. I always at least use some 80 to rough things up...40 or 36 if I have it handy.
Chris
Old 11-19-2002, 09:45 AM
Maverick's Avatar
Post
www.zerorust.com this is what Iam useing as my first coat to bare metal. Then primer/sealer then paint. Probably will do the bondo/fill thing after the primer/sealer. This stuff is a lot easier and safer then POR 15.
Old 11-19-2002, 09:54 AM
Maverick's Avatar
Post
www.hotrodscustomstuff.com/RumblinRag-06.html
Check this out! This will kinda show you how its done, give ya a good idea any way. Theres a bunch of build ups on this site to check out.
Old 11-20-2002, 01:22 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Post
Best bet and for a permanent fix would be to cut out the rust and weld in a patch.
Kevin
Old 12-17-2002, 11:25 PM
Question
[quote]Originally posted by TurboS10:
<strong>The rust converter I have used do need rust to react with. In changes it to a hard primer like coat.
Chris</strong><hr></blockquote>
hmmm
I hope you don't mind a dumb question. What exactly is rust converter?
The reason I ask is that one of my sons just bought a '62 Chevy pickup that's about 75% truck and 25% rust.
Would this stuff help? I told him I thought he needed to sand everything down to the metal, but I've never actually done any of this myself.
Any advice would be greatly appreciated.
Thanks.
