Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-31-2002, 11:39 AM
neil madsen's Avatar
neil madsen neil madsen is offline
BLACK BEAST
Question Whats the best way to build a "under the hood" 454????
Just wondering how to build a fast engine and keep all of the engine under the hood in my 1980 Z/28.What would be the best way to do it? <img src="confused.gif" border="0">
Old 10-31-2002, 12:09 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post re: Whats the best way to build a "under the hood" 454????
2 tablespoons salt, 3qts distilled water, 1 teaspoon parsley, 1/2 cup flour, bake in oven for 2 hours at 350* rotating 180* after 1st hour.
Old 10-31-2002, 03:04 PM
BLACK BEAST
Damm, it didn't work that great.Just not alot of power in that recipe.It just needs a touch of spice,just not sure what one.....LOL
Old 10-31-2002, 07:02 PM
Super Streeter Super Streeter is offline
First,go out and get the correct mounts.They installed bigblock in camaors from 70 thru 72 and the factory mounts set the engine almost 1" lower in the frame.I dont know if the mounts are still available,but I think they are the same mounts used on 69 camaros with bigblocks as well as the 302 smallblock,and I know those mounts are avalable from reproduction suppliers.I think Year one or Paddock or somebody such as that has them.Even with the low mounts,you have to run a low intake.I think that with a factory L78or LS6 intake you might be ale to package it,but it will be close.You will definatly need a drop base aircleaner and any kind of carb spacer even a nitrous plate is out of the question.Hood clearance on your car is tight,and as a last resort you might have to try and tweak the hood a bit.I have done this swap plenty of times,but I always has some sort of hoodscoop on the car.Good luck.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
