What's the best way of checking for a misfiring plug - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2003, 12:19 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
I have an intermittant problem on my SBC, sometimes when I run the engine it seems like I have a plug not firing. Whats the best way of checking it while the engines running?
Regards
Mark
Old 07-12-2003, 12:54 AM
mstngjoe's Avatar
If it's not constant, it might be tough to spot.
If it was missing at idle for instance, you could disconnect one plug wire at a time. If it got worse, that plug & wire would not be the culprit. Only if it didn't get worse when you pulled a wire would you be able to id the bad one.
You could pull all the plugs and see if one sticks out as having a misfire as compared to the others.
You could also put a tester to the wires and check their resistance. Could be a bad wire there too.
Old 07-12-2003, 01:44 AM
If you have HEI, I wouldn't pull a plug wire. Not again, anyway. Shocked the he!! out of me, & blew the module to boot. When they said High Energy Ignition, they weren't kidding. I'd pull one wire at a time with the engine off, then put it on an old plug that was grounded to the engine. Then check rpm on a tach for comparison.
Old 07-12-2003, 02:07 AM
malc's Avatar
Living At The Speed Of Life
I got me a little tester,it is a cylinder with a groove cut at right angles.In this you put the plug lead and when earthed to the car body the cylinder has a light in it that flickers to let you know the plug is working.So far so good,I found the plugs were all working, but visible evidence showed nš7 was fouled,if itīs a Chevy check nš7 first.
Old 07-12-2003, 03:22 AM
You think that's bad, ever been zapped by a MSD? Your whole arm goes numb for a while!
Jim's right though, you don't want to just pull leads off with no where for the ignition energy to go as damage may result.
malc, thanks, you just reminded my that I have one of those tools somewhere. I will have to find it now.
Lots of potential problems. Coil, leads, plugs, cap, rotor. Could also be mechanical, valve etc.
Old 07-12-2003, 11:19 AM
try your timing light on each wire first dont pull wires it hurts like hell trust me if all lights up pull out one plug and ground it to somthing and spin motor look for spark
Old 07-12-2003, 11:57 AM
mstngjoe's Avatar
Yeah, I'll admit you guys are correct on that HEI stuff.
My bad on that.
Old 07-12-2003, 12:37 PM
Gas Guzzling Democrat
my #7 plug is really bad too, from a 350. Is this a known chevy problem?
Old 07-12-2003, 01:45 PM
malc's Avatar
I think itīs to do with coolant flow,that cylinder is furthest away
and runs hotter.That is why they reversed the flow of coolant,
to the heads first.
Someone will put me right!
Old 07-12-2003, 01:58 PM
kiaserknife's Avatar
just fire the engine cold let it run about 10 seconds, then dip your finger in water and touch it to the exhaust manifold by each plug.
the one that is dead or misfiring will be the coldest one, just listen for the hiss.
Old 07-12-2003, 03:03 PM
malc's Avatar
First find an "innocent" to do that one!
My father gave the plug lead on his Triumph motorcycle to my mother to hold,the"innocent".Then spun the magneto.
Test positive.
Old 07-12-2003, 08:19 PM
lakecityg's Avatar
start your engine and let it run for a minute. then remove your oil dipstick and touch it aganist each header pipe. do that to each one. they will all smoke except for the one which is not firing. hope this helps
Old 07-12-2003, 09:23 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I usually use a little spit on my fingertip when checking the header temps, the spit turns gooey and sticks a little longer. Especially after drinking a little soda or eating a candy bar.
Old 07-13-2003, 04:21 AM
You can also spray WD40 on the exhaust manifold/header by the exhaust port. It will smoke away on the ones that are firing, but not one the dead one. Might not do to well on the siamesed ones though. Works on a big-block.
Old 07-13-2003, 12:08 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Why not just spray water from a bottle onto the header tube near the head? No one gets hurt this way.
