Whats the best way to flush an engine?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2012, 05:56 PM
just bought a 1988 chevy 1500 truck with a 350... I took off the valve covers to change the gaskets and there is alot of sludge built up inside of covers and on the heads. I have cleaned them up some but am worried about the oil screen. I was told i could drain the oil and add about a gallon of diesel fuel and let it sit,and drain it after about 2-3 hours , but aint sure. any good ideas???? thanks
Old 05-29-2012, 06:36 PM
LATECH's Avatar
Diesel fuel and rislone and all the other things are snake oil.
There is not substitute for good ol maintenance, like changing oil frequently.
I see you just got it and it was that way, not your fault , I know.
Best thing to do at this point would be to pull the motor out, tear it down , clean out the sludge and reseal the engine.Install with fresh oil and filter.
Or, dont disturb any of the sludge and just change oil to a quality detergent oil, and change it a few times ,like say at 1000 miles each time.
Stirring that pot is sure to bring trouble,if you scrape at it here and there , you will break crap loose and some will go down to the pan and ultimately end up in the screen of the pickup, plugging it and croaking your motor.
Just had a sludge motor come back after a timing chain replacement. Chick drove it 3000 m iles on the oil change we put in, didnt listen to us about changing it.All the crud was in the oil and the oil was cleaning the engine. But she didnt change it in 1000 miles like we told her to. It looked like mollasses when I drained it, and the pump screen was plugged.
Pretty costly lesson, sad thing is , the girl just did not seem to get it.
Fact is stranger than Fiction
Old 05-29-2012, 07:25 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Heed LA's advice. Sure as you go messing w/diesel fuel, ATF, or Siloo engine flush, etc, you'll end up w/a smoking mess- if the shellac that's built up, like on the valve stems, is removed, the hard-as-a-rock oil seals (unable to conform to the now smaller OD stems) will be free to pass motor oil straight into the combustion chambers.
Hold off until a proper dis- and re-assembly can be done.
Old 05-29-2012, 09:27 PM
Banned
Switch to a good oil like valvoline conventional (best oil for the money) and add a quart of marvel mystery oil every oil change. I bet within 4 oil changes 90% of the sludge will be gone. Mobil 1 is also great for this but costlier. Also use a good filter and be sure to change every 3,000 miles.
Old 05-30-2012, 07:09 AM
Thanks guys for the feed back, im just going to clean up the covers and put back on and do as ya'll said thankyou
Old 01-09-2015, 08:29 PM
Jmark's Avatar
I was going to be a smart A** and say a really huge toilet but thought twice and decided to suggest Auto-RX for a good, safe cleanout. Read the test results at the bottom, pretty impressive.
Hope this helps too.
Mark
Old 01-10-2015, 06:20 AM
Richiehd's Avatar
JS-70
Amsoil makes a product that works pretty well
5240575 – RICHARD WEBER *
https://www.amsoil.com/shop/by-produ...code=FLSHCN-EA
what to flush engine with gw1626 Engine 8 07-24-2010 06:21 PM
Engine Oil Flush 4811 Engine 0 06-18-2004 11:39 PM
Is Engine Flush OK to use? Chevy Guy General Rodding Tech 10 09-06-2003 01:45 PM
How do I flush rust out of my engine? hiimed Engine 26 07-10-2003 04:43 PM
Engine flush blockhead Engine 5 10-15-2002 04:02 PM
