What's the biggest engine that would fit a 94 firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 06:50 PM
I need to know the largest engine the would fit my 94 firebird?
Old 04-10-2006, 07:17 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
how big of a shoe-horn do you have?
Anything will fit in there, it depends purely on what you're willing to cut!
Any smallblock, however, would be a pretty easy swap in with minimal anger-management needed
K
Old 04-10-2006, 07:38 PM
lowROLLERchevy's Avatar
... & Insanity Ensues .....
Last wiki edit: The FREE T Bucket plans Last photo:
Wiki Edits: 22
jon moss managed to wedge 572ci worth of displacement into one of those camaros
the problem with that bodystyle is that even with a stock engine, the easiest way to change the spark plugs is to pull the engine. one off the local f-body guys has it down to an hour, doesnt even pull the drive shaft either ....
yopur best options are the LT1, LS1, ls6 engines can all be bored and stroked for more displacement
are you thinking of ramming a big block under the hood ?
Old 04-10-2006, 11:25 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I've heard of Caddy 500s going in. They can be pretty easily bored and stroked to 529. A BBC will fit (a bit heavier than the Caddy) and they can be taken to 540 with lots of money.
Old 04-11-2006, 08:13 AM
bigbadbowtie's Avatar
Bottle Fed
There was 762 in one this last weekend at the outlaw race
Old 04-11-2006, 10:00 AM
machinist & fabricator
with a bit of cutting and welding you could drop a 1937 linclon zypher v-12 in it!
Anyone happen to know the firing order or a 94 firebird? Vegaburnout Engine 5 04-03-2005 09:41 PM
Will my 350 fit? 94 Firebird NXS Engine 5 12-09-2004 10:23 AM
1994 pontiac firebird engine swap john34683 Engine 1 09-16-2003 07:31 PM
Firebird engine specs??? frank_a86 Engine 0 08-05-2003 06:25 PM
biggest tires to fit on 18x9.5 swoodard23 Suspension - Brakes - Steering 4 01-13-2003 04:36 AM
