Whats this bluish spot on rod beam? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2006, 11:31 PM
I took a set of rods out of my olds engine to get resized, the other two were from a different engine as the first set had 2 spun bearings.
Anyway, I inspected these rods before they left and after I got them and all looked good. But, now after I washed the pistons and rods for assembly I noticed the two rods that were from the different engine both had a bluish colored spot on both sides of the rod about two inches from the small end of the rod.
What would make these get colored like that and are they OK to use? The machinist checked out these rods and resized them and said they were fine.
Any advice?
Old 03-04-2006, 11:43 PM
Infomaniac's Avatar
Twin Turbo Drag Boat
Last journal entry: Random In Progress Shots
The rod heater does this when press fit pins are installed. Perfectly normal. Could be from a previous install if not blued all the way to the pin.
Old 03-05-2006, 03:12 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
agreed. Press-fit pins are somewhat of a misnomer. Its a tight fit, but its accomplished by heating the rod and cooling the pin. Once assembled and allowed to return to normal temps its a press-fit.
If you were to just press the pins in the rod under normal temperatures it would cause stress fracturing and distortion of the small end of the rod.
Old 03-05-2006, 09:42 AM
Ok, thanks
Junkyard Motors.. Zartan Engine 20 07-08-2011 07:52 AM
c6 downshift rod theory and practice cboy Transmission - Rearend 6 03-10-2005 05:17 PM
Rod and piston question Ratoflic Engine 2 02-10-2005 07:34 PM
?? Bore Sizes ?? ss crazy Engine 2 10-03-2003 02:51 PM
Q-Jet Metering Rod Idea Silver_Camaro Engine 6 09-16-2003 01:48 PM
