-   -   What's the code? (http://www.hotrodders.com/forum/whats-code-8970.html)
5window 07-04-2002 09:48 AM
What's the code?
I've got a GM 10 bolt rear end the with the code "JD 311" stamped on the right axle housing. Anybody know what this means? Thanks
5window 07-04-2002 10:25 AM
Okay, I had the codes wrong. On the front of the right axle housing it says "JD G308 1". On the rear at the differential it says "67890" upside down. On the differential brace it says "J231" Any help?
