What's the code? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2002, 09:48 AM
Question What's the code?
I've got a GM 10 bolt rear end the with the code "JD 311" stamped on the right axle housing. Anybody know what this means? Thanks
Old 07-04-2002, 10:25 AM
Post
Okay, I had the codes wrong. On the front of the right axle housing it says "JD G308 1". On the rear at the differential it says "67890" upside down. On the differential brace it says "J231" Any help?
