what's the correct wheel back spacing for 68 camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2004, 12:48 PM
68camaroguy's Avatar
I have a 68 camaro that had 4 wheel manual drum. I converted the front to disc and also added a power booster with new master cylinder.
the problem that i'm having is now my tires are rubbing on my inner fender's. the spindles that i put in there are from a 69 camaro. The spindles did push out the tires a little.
my question is how can i fix this so they dont rub. is it simply get new rims with a different back spacing or can i get different size tires. I have old shool SST rims .I have 14 in rimes in the front running 215,35,14
thanks for any help
