Whats The Deal W My Hot Carb??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2008, 02:48 PM
chevy bb 572's Avatar
CHEVY BIG BLOCK 572
Last journal entry: sum rides i got
DRIVING MY CAR 2DAY AND I HEARD A HISS SOUND DROVE AROUND FOR ABOUT 3 HOURS AND IM COMMING UP THE PLOCK AND SHE SHUTS DOWN. OPEN HOOD TAKE AIRBREATHER OFF IT HOT AS !@#%$^*%^$ CARB IS BLACK W CARBON I WAIT A FEW MIN TRY 2 START IT WONT START SO I SHOOT STARTING FLUID IN AND SHE STARTS UP SO I HURRY AND GO HOME AS IM PULLIN IN DRIVE WAY SHE SHUTS DOWN WHATS THE DEAL??? BLACK HOT *** CARB!!! OH ITS A HOLLEY 600 IVE NEVER HAD PROBS. WITH THEM
Old 10-17-2008, 03:12 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
It sounds like you have a major vacuum leak. Check your vacuum caps and hoses at the base of the carb, and in the intake manifold. One could have cracked and fallen off.
OH, Another thing to check is your 'caps lock' key!
Old 10-17-2008, 03:36 PM
I would expect 3 possibilites
1) That the hiss is related to a vacuum leak causing the mixture to go lean and resulting in overheating the engine.
2) The cam has fallen out of time (retarded) because of wear in the timing chain and gears, resulting in fire getting out of the cylinders and into the intake. this could also be the distributor is out of time without regard to cam position relative to the crank.
3) The exhaust crossover under the manifold has burnt thru putting hot exhaust into the intake.
Bogie
modifying that too rich edelbrock 1405 carb? TVR383 Engine 23 12-03-2009 09:19 PM
Would you buy the Hot Rod or a Diamond for Your Girl? Tell Us! prismstar Hotrodders' Lounge 2 06-04-2006 05:21 PM
Need help with Edelbrock carb Crazy-J Engine 1 06-01-2005 02:24 PM
desperately seek opinions for carb choice txsfld Engine 53 11-22-2002 04:08 PM
priming a new edelbrock carb crshrmn3 Engine 8 10-29-2002 05:04 PM
