what's the diff? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2007, 02:47 PM
atotalnincompoop's Avatar
Last journal entry: 46 mercury bobber pickup
what's the diff?
can anyone tell me what kind of diff this is?
everyone i know is telling me something different, no two people who i have had over here looking yet have told me the same thing.
Old 10-21-2007, 03:31 PM
the numbers are 522498, just above the numbers is a m inside a square cast onto the carrier
Old 10-21-2007, 03:53 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I say Ford 9", but the casting number looks more 8".... but I don't recognize those support ribs in the casting as an 8", AND the shape of the case is too round for an 8".
Do the axle tubes taper at the end? If so, it might be an early 9" (pre 67)
So I guess I'm saying... I dunno.
Old 10-21-2007, 04:05 PM
Wiki Edits: 49
Sure looks to me to be a Ford. It's not a 9" but could be a 7.5".
Old 10-21-2007, 04:14 PM
they don't appear to taper, would it be a slight taper or something that would be obvious without having to measure?
Old 10-21-2007, 04:15 PM
Notorious's Avatar
Hot rodder, not street rodder!
I'm not familiar with those, what were they used in?
Anyhow, I've got both 8 and 9 inch housings around and several third members too. I've never seen a Ford third member that looked like that one though. Could it be early GM? And although I've had quite a few 8 3/4" Mopars over the years too, I haven't had one in quite sometime and so have none here to look at.
Old 10-21-2007, 04:20 PM
here's a '57 and up 9"
8"
7.5"
a 9' "caf22c" whatever that is
and a 9" pro 57 and up
Old 10-21-2007, 04:32 PM
Notorious's Avatar
I've got a '58 large bearing housing and there's no taper in it. I don't have any small bearing 57-59 housings anymore. I don't know if they were tapered or not.
As a possible clue, what is the bolt circle size of the wheel studs? 4.5", 4.75", 5" or 5.5"?
Old 10-21-2007, 06:25 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
61 - 63 chevy 3/4 ton truck ?
Old 10-21-2007, 06:57 PM
the bolt circle is 5"
Old 10-21-2007, 07:07 PM
the brake backing plate mounting flange is shaped similarly to the gm 10 and 12 bolt, tapered from top to bottom( trapazoid shaped), with flat sides, a curved bottom side and a slightly pointed top side
Old 10-21-2007, 07:08 PM
denno5644's Avatar
All Throttle No Bottle
Looks like early 60s olds to me
Old 10-21-2007, 07:13 PM
pontiac is my guess! get the casting numbers off the wheel cylinders and run them on the bendix website. post your results.
Old 10-21-2007, 07:23 PM
i'll get those numbers tomorrow, good idea
Old 10-21-2007, 09:19 PM
Vortech 4.3's Avatar
jack of all trades
thats what i was going to say.
65 posi diff. popa60 Transmission - Rearend 2 09-08-2006 02:05 PM
used diff gears rumpity_z28 Transmission - Rearend 3 06-05-2005 02:38 PM
GM 10 bolt Diff ID numbers? Gearhead forever Transmission - Rearend 8 04-27-2005 09:45 AM
ford 8 3/4 diff Snake Eater Transmission - Rearend 1 11-13-2004 01:07 PM
posi diff identification sportsman69 Transmission - Rearend 3 10-30-2004 10:44 AM
