whats the difference between carter afb and edelbrock carbs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2004, 11:18 PM
Super Chevy's Avatar
BRB carring
what is the difference? they look identical. they both say weber on the side. and there is $70 difference between the two at summit. are you just paying for the edelbrock name?
thanks
Once you go flat black you never go back.
1966 El Camino
1992 Dodge Shadow
1986 S-10 Blazer 4x4 Hot Rod
1970 Chevelle
1966 Chevelle 4 door
Home Made Go Cart
Old 03-22-2004, 11:23 PM
DoubleVision's Avatar
there really is no difference from what I`ve seen. I doubt one would make more power over the other, they are good carbs, but I don`t like either for various reasons.
Old 03-23-2004, 01:42 AM
lust4speed's Avatar
Edelbrock wanted to expand and carry carburetors, and it was much more cost effective to purchase existing designs. Looks like both Carter AFB and Rochester Quadrajet were receptive to selling. What surprises me is that I see that Edelbrock has actually brought out new models in both series. And regardless of your feelings for specific brands, competition will give us a better product from all manufacturers.
I'll bet the Edelbrock is the more expensive carb? I know that the Edelbrock rebuild kit is a lot more money than the Carter, and both rebuild kits are the same as far as I can tell.
Old 03-23-2004, 05:37 AM
Wiki Edits: 49
The only real difference in the two is the length and spacing of the steps on the metering rods. I'm not sure if they are interchangeable but most likely are. Both the Carter and Edelbrock carbs are manufactured by Webber (as the WW casting mark on both carbs indicates) and they come down the same assembly line.
For most all street combinations these are really good carbs. It's very hard to over carb with an AFB design like you can easily do with a Holley. The Holleys have tuning advantages when it comes to all out racing though.
Centerline
Old 03-23-2004, 08:15 AM
deuce_454's Avatar
same difference
they are both made by webber carburators USA on the same assembly line by the same peoplem, the metering rods might be different but they are interchangable,
Old 03-23-2004, 10:23 PM
BRB carring
thanks, im not getting either of those anyway but i was just curious. but if i did want one id save the $70 and get the afb and stick an edelbrock sticker on the front name plate. no one would know the difference lol.
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 03-23-2004, 10:30 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
What other carbs are on the market now, besides Holly, Edelbrock, Carter, Webber and Demon?
Old 03-23-2004, 10:49 PM
BRB carring
DaVinci
1966 El Camino
1992 Dodge Shadow
1970 Chevelle
Home Made Go Cart
Old 03-23-2004, 11:11 PM
Jared's Avatar
BG, quick fuel, preditor,proform may make them? i know they make holley type main bodies.
Old 01-06-2006, 03:58 PM
Mike
Hello.
Can anyone here tell me if the electric choke conversion kit for the Edelbrock carburetor will work with the Carter Competition AFB?
Thank you.
Mike.
