whats the difference between these 2 heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2009, 11:09 PM
whats the difference between the brodix jj 180 and the ik 180? they have the same flow numbers at .500 lift. is it just the different chamber sizes?
thanks
Old 02-23-2009, 09:04 PM
cool rockin daddy's Avatar
Call Freakin' Brodix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!1
Old 02-23-2009, 09:34 PM
i tried 3 times. got a different person each time. none could help for some reason. im thinking about going with afr now...even though they are $500 more. they picked up on the first ring and answered all of my questions.
anyone else?
thanks
Old 02-23-2009, 10:06 PM
only difference is JJ version is powder coated black with iron 'schneider cams' looking crosses and the iron killer is a natuaral aluminum finish... not sure but I'd bet the jesse james versions sells for a bit more than the IK series... good marketing dept!
HiPo heads RJL Engine 16 06-29-2009 09:18 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
FE blocks SAATR Engine 27 03-14-2005 04:35 PM
What are the best heads to put on a 305? CCR Engine 6 11-06-2004 01:50 PM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
