What's the difference in C5 C6 and ZO6? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 01:12 PM
Larry3's Avatar
I am short on knowledge about late model Corvettes. I need to know because I am doing a front brake upgrade on my 83 Camino.
Any help would be greatly appreciated! Or a link to that kind of info.
Old 07-27-2008, 03:00 PM
10mikeymike's Avatar
C5, C6 & Z06
C5 and C6 are the previous and current generations of Corvette's respectively. I don't know about the C5's but I have a C6 (2006) with the Z51 suspension package. Part of the package was larger, drilled brake rotors front and rear. The current generation (C6) Z06's have enormous brakes consisting of 6 piston calipers and huge rotors. Offhand, I don't know the diameters. I know they aren't interchangebale on the standard C6 Corvette's unless you do a wide body conversion front and rear using Z06 fenders and quarter panels and then you need wider rims to accommodate the larger calipers. Check out corvetteforum.com for additional info. There's a section dedicated to Z06's and there's plenty of information on brakes as well.
Old 07-27-2008, 03:44 PM
Larry3's Avatar
Thank You Sir!
Thanks a lot, i will check it out.
New C6 ZO6 Vette lousy paint job. 302 Z28 Body - Exterior 4 07-17-2006 04:08 PM
