What's everyone doing in the Garage? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-09-2006, 06:44 AM
wildfire78's Avatar
wildfire78
Getting set to pull the bench seat in the 78 D100 and install buckets. Once they are in, I have a floor shift to install and will then build a custom console around the shifter.
  #32 (permalink)
Old 03-09-2006, 09:25 PM
Ole 53
I spent the afternoon building front motor mounts for the ole 53. It's a 55 engine, so instead of drilling out the holes for the original mounts. I built supports for the 55 mounts, with 5/8x095 wall tubing, and plates welded to the frame. The ole 6 is all mounted now. I had to pull the engine out of my 48 and use the bellhousing and some other parts for the 53. I'm also using a 16 gallon fuel cell. It's 24x18x14 just fits between the frame rails behind the 3rd member and the rear cross brace on the frame where the spare tire mount used to be. I never liked the idea of a gas tank right under my a## if ya know what I mean. I'm gonna put all new brakes, brake lines, fuel line, wheel cyls, master cyl next.
  #33 (permalink)
Old 03-10-2006, 09:55 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
hopefully this weekend it dries out a little.... i want to finish painting my engine bay... then the engine can go back in. if not it will be working on the bar stool and lights on the workbench...
  #34 (permalink)
Old 03-10-2006, 10:28 AM
Hopefully laying some paint on my Z28. I am putting a cowl hood on. BranZ
  #35 (permalink)
Old 03-12-2006, 08:42 PM
39deluxe's Avatar
Never Finished
I just put the new engine I built in the '69 stepside and finished the front brakes and suspension. Next is fuel systen, exhaust and power steering.
Name:	Engine Drop MVC-014S.JPG
  #36 (permalink)
Old 03-13-2006, 09:34 AM
Don Meyer's Avatar
I've been working on a 48 GMCfor the past 2 yrs. I make too many body mods that take forever to finish....http://71.65.63.136/web/photos/default.aspx
top chopped
cab & doors extended
modern narrowed bed w/Caddy fins
GM G-body front clip
Ford 9"
350/700r4.
  #37 (permalink)
Old 03-13-2006, 10:12 AM
jvsapp's Avatar
top chopped
Ford 9"
350/700r4.
very nice don... i like the caddy fins and the bed filler...
  #38 (permalink)
Old 03-13-2006, 02:26 PM
Don's 48
Don, nice ride, I'd like to know more about your custom dash in the 48.
thanks, resto1944- ya can see some pics of my junk here.
http://community.webshots.com/user/niteowl01244
  #39 (permalink)
Old 03-13-2006, 07:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Finishing up the headlight/tail light wiring then on to the body work to repair a bad rear quarter installation. Engine and dash is wired, got it started and tuned. Had some issues mounting the alternator low on the passenger side, modified a Zoops bracket. Still need to install the new glass and maybe try to shoot some color on this summer if I can stop driving it long enough.
  #40 (permalink)
Old 03-14-2006, 09:36 PM
I'm still working on my 52 Ford F-1 pick up. Got the 327 Chevy mounted in the S-10 frame. I moved the trans mount back 2" and got rid of the two piece driveshaft along with the center carrier. Instead I used a one piece driveshaft from an 88 Chevy station wagon. Everything dropped right into place. Last week I measured and mounted the cab. This week I did the brakes and redesigned the E-brake. I'm taking my time and working on it a few hours a day. Gotta spend some time this week cleaning up a mess. The cooler line popped off when I started the engine, now I've got tranny fluid everywhere. I'll also spend some time updating the website about the S-10 frame swap.
www.geocities.com/lakota_circle_dancer/swap1
  #41 (permalink)
Old 03-15-2006, 11:05 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Monday I start work getting ready to pour the concrete floor of my new 30x50 shop! Have some filling and packing to do. Had the pole barn put up over the winter (it's in SC) with one 50' side off so I can back in and pour the floor. I'm USAF and stationed in Delaware, will retire in a year and the shop will be ready to go.
  #42 (permalink)
Old 03-15-2006, 11:20 AM
Just got done last night with the final brake lines and installed the torque converter in the tranny and the tranny to the engine in the 48 chev p/u. About the only thing left on the drivetrain in the driveshaft and I can't seem to catch the guy at home who makes them. As soon as it warms a little the cab gets put in the shop and body work starts. Come on Spring!!!
  #43 (permalink)
Old 03-16-2006, 07:39 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
I'm getting ready to get the Hemi out of the basement and out to the shop for the finishing touches before I start it for the first time. I built a stand for the engine to sit on. Got a 1 gal. fuel cell and radiator off of e-bay that I'll use on the test stand. Still have to pick up a fuel pump, radiator hoses, and do the wiring. Then it's ready to start.
Steve
  #44 (permalink)
Old 03-16-2006, 08:44 AM
dermott's Avatar
1937 hudson terraplane coupe
hi evertone, it is cold one day then t-shirt the next up here. my coupe is orig 48 thou on the car never been touched mech. but re-paint i believe by tracking her in the late 80,s . 212 flatty,3 spd w/this dreaded wet clutch. i got this coupe in 2004 because the owner knew nothing about how to fix the clutch. i flushed all winter of 04, there are 80 little cork inserts in there in 6 o.z. of hudsonite fluid [type f, very close i am told ?? ]. i drove last summer about 1 thou miles. not bad but, on inclines the coupe would shake , rattle and roll hard 1 st to 2 nd, people in mod cars would back off thinking it would blow, but level roads with no lites to stop me are good. i flushed again this winter [05] and will drive this summer, mayby.. i am gathering info on going in-line g.m. blue flame 6 w/auto [powerglide ?] thm350. s-10 rear end. but a unique combo is a rambler in-line w/auto, wierd coupe [orfan] with strange combo? anybody seen this heard, problems vs. easy install. i have info on g.m. change but not a.m.c. which was hudson/nash untill 1957. early 60-64 6 cyl and tooling must be close? and/or any one hop-up a 212 flathead? use 50,s hornet motor parts. that is what i am doing in my garage. i will try to get pics of coupe on soon. and 32 de soto, that coupe was the first car i dragged home, not yours of corse but a 32 3 window w/rumble found in the woods at 10 years old. my parents flipped. later about that. sorry i write too much , talk soon.
  #45 (permalink)
Old 03-16-2006, 09:18 AM
73oldsman's Avatar
Originally Posted by steve392
I'm getting ready to get the Hemi out of the basement I built a stand for the engine to sit on. Got a 1 gal. fuel cell and radiator off of e-bay that I'll use on the test stand. Steve
Now that sounds like fun!
Maiting calls of the garage Halloweenking Hotrodders' Lounge 22 09-19-2006 09:18 PM
Garage Safety Kevin45 Garage - Tools 48 11-26-2005 08:49 PM
Hotrodders Knowledge Base: Garage - Tools Jon Garage - Tools 0 11-26-2005 06:46 PM
Some more ideas for the garage Kevin45 Garage - Tools 7 01-28-2004 11:36 AM
