Whats the gear ratio in a 1972 pontiac lemans
Whats the gear ratio in a 1972 pontiac lemans, not sure what was originally in it for a motor. It now has a 389 out of a 1965 GTO. Dont pick on me cuz I'm dumb!!! Im a girl so I need a little help.....Please
This will probably have the corporate 8.5 10 bolt rear end in it. If it has a standard differential then leave one wheel on the ground and turn the other wheel exactly 2 full turns. If the drive shaft turns just past 3 turns then it's a 3.08, if it turns 2 3/4 turns then it's a 2.73, if it turns close to 2 1/2 turns then it's a 2.56... If it has a good posi and both wheels turn together the same direction then turn both wheels exactly one full turn and watch the drive shaft. It helps to have at least 2 people do this.
The best way to do it is to remove the cover and count the teeth. Divide the number on the ring gear by the number on the pinion. 41/15 = 2.73 The oil probably needs to be changed anyway, so this would be best. |
The stats section at ultimategto.com may shed a little light on what it came with from the factory. If i were to guess I would say 2.73 as the EPA was starting to crack the whip.
| 1972 Pontiac LeMans Brake Lights | David Krogh | Electrical | 3 | 08-21-2006 02:26 AM |
| Judging gear ratio with tire size? | gpeak | Hotrodding Basics | 2 | 06-27-2004 11:27 PM |
| Cam and rear gear ratio with blower??? | 84Z | Engine | 4 | 05-29-2004 07:22 PM |
| What Gear Ratio | 79 Malibu327 | Engine | 5 | 04-12-2004 11:30 PM |
| Gear ratio, confused | Bluepen | Transmission - Rearend | 1 | 04-01-2003 06:02 AM |
