Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What's a good tranny replacement for my 62 Pontiac Catalina?
Old 01-08-2002, 04:09 PM
Noggin Noggin is offline
New Member
Post
You should be able to get just about any GM Automatic to fit up to the 389. The only thing you may have to worry about is the trans mount.
Personally I would select the TH350 unless you opt for overdrive. Then a TH700r is the puppy.
I you plan to put a load of power down you will need to do a little more research.
Noggin
