Hey Albert, If you want to run an overdrive tranny, there are a couple of things to keep in mind the 700r4 will not just bolt up. You will need to get an adapter plate. The 200r4 is made so it fits all the GM brands B.O.P.& Chevy they can be pretty expensive to build. Or you can go with a 350 turbo. Becase your car is a land yacht I would use a long shaft 350. need any more help let me know
