-   -   What's a good value PPG epoxy & urethane primer? (http://www.hotrodders.com/forum/whats-good-value-ppg-epoxy-urethane-primer-219256.html)
TNshadetree 05-11-2012 11:49 AM
My local supplier carries PPG. On my last paint job I used Global products because I didn't have much experience and wanted to ensure I was using the best products.
But my current project is being prepped for resale so I'd like to control cost as much as possible but still not be so cheap I cause myself issues. With all of PPG's lines, Shopline, Shopline Plus, Deltron, Omni etc. I'm not sure which direction to go.
I'll be needing
an epoxy primer,
a 2K urethane primer,
then single stage white and I may add some clear to my last coats for effect and easy cut and buff if needed.
Which product lines (and product #'s) will save me some expense and still perform well?
dtracy 05-11-2012 03:04 PM
I used to use PPG DP-40 epoxy primer and Deltron color coats. The Deltron goes on good, is easy to color sand and buff, and looks great. However, in Arizona it doesn't hold up very well out in the sun. Kind of like old laquer.
Dave.
bighotroddin 05-11-2012 03:32 PM
I use the Omni MP170 epoxy primer and the Mp282 high build primer. Both of these are half the price of the Dp40 and K36 primers and work just as good.
For whats its worth it is probly easier to go with a base/clear system if you are going to wet sand and buff it any way. I would get the DBC base coat as the omni doesn't cover as good and it will cost the same in the long run.
I buy my stuff at Finish Master and they sell Zolatone and Transtar clears with both work good and are under a $100 a gallon.
TNshadetree 05-12-2012 09:31 AM
I think I've used the Omni epoxy before. Good to hear about the MP282.
Most of the complaints I hear about Omni are about base coat coverage. Is the Omni clear good stuff?
bighotroddin 05-12-2012 04:17 PM
I've never used.
I painted my friends 18 ft boat and with 3 coats some areas were light. I have had better results with the single stage.
