What's a good value PPG epoxy & urethane primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 11:49 AM
My local supplier carries PPG. On my last paint job I used Global products because I didn't have much experience and wanted to ensure I was using the best products.
But my current project is being prepped for resale so I'd like to control cost as much as possible but still not be so cheap I cause myself issues. With all of PPG's lines, Shopline, Shopline Plus, Deltron, Omni etc. I'm not sure which direction to go.
I'll be needing
an epoxy primer,
a 2K urethane primer,
then single stage white and I may add some clear to my last coats for effect and easy cut and buff if needed.
Which product lines (and product #'s) will save me some expense and still perform well?
Old 05-11-2012, 03:04 PM
I used to use PPG DP-40 epoxy primer and Deltron color coats. The Deltron goes on good, is easy to color sand and buff, and looks great. However, in Arizona it doesn't hold up very well out in the sun. Kind of like old laquer.
Dave.
Old 05-11-2012, 03:32 PM
I use the Omni MP170 epoxy primer and the Mp282 high build primer. Both of these are half the price of the Dp40 and K36 primers and work just as good.
For whats its worth it is probly easier to go with a base/clear system if you are going to wet sand and buff it any way. I would get the DBC base coat as the omni doesn't cover as good and it will cost the same in the long run.
I buy my stuff at Finish Master and they sell Zolatone and Transtar clears with both work good and are under a $100 a gallon.
Old 05-12-2012, 09:31 AM
I think I've used the Omni epoxy before. Good to hear about the MP282.
Most of the complaints I hear about Omni are about base coat coverage. Is the Omni clear good stuff?
Old 05-12-2012, 04:17 PM
I've never used.
I painted my friends 18 ft boat and with 3 coats some areas were light. I have had better results with the single stage.
Epoxy Primer, Urethane Primer Compatibility brimcp99 Body - Exterior 7 11-22-2010 07:04 PM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
Epoxy Primer & 2K Urethane Primer acquadigio79 Body - Exterior 17 08-15-2009 04:07 PM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 05:50 PM
Good epoxy primer? Since New PPG dplv stinks on bare metal? zachscc Body - Exterior 3 11-15-2003 10:25 PM
