What's the "IDEAL" chassis for 37 Chevy Coupe Rebuild? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 11:17 AM
Planning to rebuild a 37 Chevy Coupe Master Deluxe into a street rod with modern chassis (disc brakes, R&P Steering, V8, auto transmission, etc). Is there an "ideal" make/model/year frame to use as the starting point? One that would provide the modern options mentioned above, but not create a great deal of customization to make the 37 body fit on the frame?? I have read about a couple '37 rebuilds and one used a Nova frame and other a Corvette. Any suggestions or experience would be welcome. Thanks!
Old 11-27-2012, 11:32 AM
YES, there is an IDEAL frame under your 36 Chevy......a 36 Chevy frame!
Use your stock frame and add all the suspension changes you want and you will not devalue the car. Put the wrong frame under it and you will.
There are ZILLIONS of different, quality, new kits to put modern from and rear suspensions on your car. Don't get into the "Frame swap" thinking.
There is NO SUCH THING as a "frame swap" to put the wrong frame under it takes a LOT of skill to do right, if it can be done at all. It only swaps Time, work and money, it saves you NOTHING.
Would you imagine "swapping" the wrong fenders or doors on the body? "Swapping" the frame is no different, it won't fit and it takes a LOT of work to get it anywhere near fitting. Most of them look like a mess and the car is ruined.
Hang out here and just learn all the different things you can do, there are tons of super knowledgeable people here just start checking out stuff. There is no need to change frames.
Brian...my two cents.
Old 11-27-2012, 11:51 AM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
That's a wealthy 2 cents Brian !!!!!
Jester
Old 11-27-2012, 12:14 PM
Faith - Respect - Trust
I know you got more good information Brian and I've got change in my pocket for a dollar. Brian is right, try (one example only, there are lots of companies) TCI...They are one company of many that make all the conversions your looking for possible.
Ray
Old 11-27-2012, 12:58 PM
1971BB427's Avatar
Progressive sells complete frames designed specifically for your car. You can buy them as a bare frame, or with various components to fit. Depends on your budget.
Progressive Automotive, 1937 chevy chassis, 1938 chevy chassis, 1939 chevy chassis, 1937 chevy frame, 1938 chevy frame, 1939 chevy frame
Speedway and others sell components to upgrade your stock frame to modern suspension as Brian mentioned. If money is a concern, then upgrading your frame is the least expensive, but you'll need to have the skills and tools to fit these parts.
A friends review of "KwikWire" brand chassis wiring kit lowROLLERchevy Electrical 13 10-05-2009 08:55 AM
wiki pages: "How to rebuild an engine", "Window removal/installation" Jon Hotrodders' Lounge 0 07-11-2006 12:44 PM
Anyone ever dealt with "Autoweld Chassis"? S10xGN Suspension - Brakes - Steering 2 07-22-2005 07:02 PM
"chevy 383 w/5.700" rod" means it suppose to come w/ rods right? jesse01 Engine 9 04-14-2005 02:44 PM
Hey croz look """"IMPORTS SUCK""" 78 monte Hotrodders' Lounge 14 08-30-2002 01:13 PM
