What's involved? Reverse pattern valve bodies - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 11:02 PM
Last journal entry: the quest for THE CAR
OK, I'm building a ChumpCar . This series really makes you do things as cheaply as possible! I'm going to be running a Ford C4 auto transmission, and I'd like the shift pattern to be reversed for the forward gears. But a valve body that's been modified for this will ding me $150, and my "competition value" can't be more than $500. Which means that I can't afford to buy this, or at least can't afford to admitting buying it. So, since I have pretty decent machining and fab skills, what goes into modifying a C4 valve body to reverse the shift pattern?
Old 04-22-2011, 12:54 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
Try the link. Hope it helps
Rich
http://www.broaderperformance.com/en...-body-kit.html
Old 04-22-2011, 06:11 AM
Within $80 of perfect! Thanks. I'll get it!
anyone know how to make a reverse shift pattern 727 valve body? the nitro man Transmission - Rearend 0 06-13-2009 11:18 AM
Can Someone Explain Reverse Pattern Valve Bodies 406 bug Transmission - Rearend 1 01-27-2008 03:59 PM
Turbo 400 with manual valve body & reverse pattern... Bumpstick Transmission - Rearend 5 12-26-2005 03:51 PM
Turbo 400 reverse pattern...? Why...? Bumpstick Transmission - Rearend 1 05-30-2005 05:56 PM
Reverse shift pattern brainsboy Transmission - Rearend 3 06-29-2004 02:51 PM
